Thread: NewBlue Titler Live 3 with DataLink
    May 2017
    Rock Rapids
    13
    We recently purchased NewBlue Titler Live 3 Sport and are having issues getting it to connect with our NewTek Data Link program. Data Link will connect with Live Text but not Titler Live 3 Sport. I don't really know where to start to troubleshoot so any help would be appreciated.
    Oct 2008
    Colorado Springs, CO
    37
    Quote Originally Posted by Gkruse View Post
    Hi Gkruse,
    I've recently started playing around with this setup as well. The one thing I noticed when I went to add the scoreboard data in Titler Live Broadcast (in our case, coming through a Daktronics AllSport CG) was that it only detected that data if it was already going into the TriCaster. We send our data feed directly to the internal version of Livetext to have it pull data instead of in the external version. That allows us to then add it into our Titler graphics because it pulls it from the TriCaster.
    Hopefully that helps. If I have more time to play around with things, I'll let you know. What's your specific issue? What type of data are you trying to import?
    Cory
    May 2017
    Rock Rapids
    13
    I ended up calling them and they told me that's the only way to make it work. They can only use DataLink with the Tricaster and not the standalone version of LiveText.
    Jun 2012
    Los Angeles
    71
    Hello. It's now 2019 and I need help setting up Datalink, Tricaster and NewBlue Titler 4 Broadcast!!
    Here's what I just left in this forum:
    Tricaster, Datalink & NewBlue HELP!!!
    I am trying to set up and use Datalink data from the AllSportsCG in NewBlue Titler 4 Broadcast software.
    In a forum post a few years ago, the following information was given: "The one thing I noticed when I went to add the scoreboard data in Titler Live Broadcast (in our case, coming through a Daktronics AllSport CG) was that it only detected that data if it was already going into the TriCaster. We send our data feed directly to the internal version of Livetext to have it pull data instead of in the external version. That allows us to then add it into our Titler graphics because it pulls it from the TriCaster."
    A NewBlue person told me that is still the case - that the Datalink data must first enter the Tricaster (which I've been able to do) before it can be picked up by NewBlue as a Newtek Datalink source coming OUT FROM THE TRICASTER and selectable in the NewBlue software.
    How is that possible? Can someone PLEASE tell me how to set that up??? I'm at a loss because NewBlue technical support has so far been non-existent.
    Thank you.
