Results 1 to 11 of 11
Thread: Recording Green in QT Player
    Feb 2011
    South Africa
    72
    Hi All,
    When pulling a TC AE recording (MOV) onto my mac with the latest QT installed, the TC footage reads as green.
    Adobe reads it fine, so I am just wondering if there s a new Apple QT codec that I need to install on my mac?
    Has the codec on the TC recording changed at all, with one of the updates or was the change on Mac's side?
    All the best
    Nino
    May 2017
    Connecticut
    5
    Quote Originally Posted by Malapati View Post
    Hi All,
    All the best
    Nino
    I literally just posted about this as I'm having the same issue. We always bring TC files into FCP to edit. Audio is fine, but video is green.
    What do you mean Adobe reads it fine? Do you mean Premier, and wouldn't that use the QT codecs too?
    Sounds like there is an issue with Advanced Edition.
    Feb 2011
    South Africa
    72
    Quote Originally Posted by rcebulski View Post
    When I pull the footage in to Adobe Premiere Pro it decipheres the footage, but playing it back in QT directly it sees the footage as green only, but with audio.
    The strange thing is that footage recorded on the latest version of Isocorder Pro is read fine by both applications. Which in my opinion points to the TriCaster as opposed to QT
    Any ideas?
    Apr 2011
    Lisbon
    2
    Have you guys fixed this by any chance?
    All my TriCaster recorded files are green in Finder or FCPX, and I'm out of ideas.
    I have the codec installed but it seems to make no difference.
    Aug 2016
    USA
    545
    Registered User Paris MkVI's Avatar
    Sep 2014
    Virginia
    111
    Do you all have the Newtek Tricaster codecs installed on your other machines?
    Tricaster 460
    HD-SDI over coax
    JVC 890 x 2
    Panasonic 370 x 1
    Oct 2018
    France
    1
    Since I update my TC8000 with advanced edition I've got also this problem.
    Codec are up to date but problem persist.
    Videos are green under QT and FC Pro 7.
    Is there a way to change recordings parameter ?
    Thanks.
    Quote Originally Posted by carlito31 View Post
    Thanks.
    What video format are you working in? Here is a list of common formats and compatibly with major NLE systems. FCP7 is really old, so I'm unable to test compatibility with it, it also means that FCP7 hasn't had any updates to deal with the media formats that have occurred in the past 8 years.
    NewTek Recording Formats.pdf
    Nov 2016
    AutoWorld
    4
    Has anyone made this to work? I've been going round and round with customer support for more than a week now. I'm disappointed that this issue has been around for more than a year now and customer support hasn't pointed me toward ANY suggestions for a fix.
    I'll try this, but would like to know if anyone else has had success fixing this issue.
    19,650
    I'm way out on the thin end of my dendrites here, but my recollection is that FCP7 always provided very limited codec support (being esp. poor at handling MPEG-2), and back in the day the web was full of workarounds, most of which involved conversion ... in witness of which, here is a typical discussion: https://discussions.apple.com/thread/2251560
    However it sticks in my mind that at one point it was possible to add a "Pro" codec download from Apple that improved things, which might be worth a try. I think this was it: https://support.apple.com/kb/DL1947?locale=en_US
    Nov 2016
    AutoWorld
    4
    Actually, I just found the issue.
    I wanted a 60fps recording from the Tricaster, and didn't realize that the only 60fps setting was 1080i. The Mac wants progressive. I created a new session at 1080p 30, and the recordings work in the Mac.
