Results 1 to 15 of 18
Thread: Premier will give up QT-support. How will tricaster handle this?
    Jan 2017
    Aachen, Germany
    8
    New Premiere 2018 gives an message when importing Tricaster's qt-files that there will be future versions of premiere that don't support 32bit-quicktime files any more. How can i handle that in my Tricaster workflow? What other format will there be to be recorded without conversion?
    Not a lot of info.
    https://helpx.adobe.com/premiere-pro...ortending.html
    I think this means that Adobe is fully dropping the Apple 32-bit QuickTime libraries. Which means no more support for 3rd party QuickTime codecs.
    Consultant
    Apr 2008
    Greater Washington, DC Area
    1,390
    This is one to watch
    Sandy Audio Visual LLC
    NewTek Certification Testing Center
    Twitter @DCTriCaster
    TriCaster: All Models
    Cameras: Sony HDC-P1, X300
    My opinion, uncensored. The blog at www.sandyaudiovisual.com.
    Jan 2017
    Aachen, Germany
    8
    Now it happened! New Premiere doesn't support qt7 Codecs any more! How can we handle tricaster recodings now?
    Aug 2016
    USA
    571
    I have Premiere CC2015. Does everything I need.
    NYC
    3,348
    You guys read that right...Click image for larger version.
    Jose Burgos
    NewTek Certified Trainer
    www.burgosfx.com
    FaceBook
    Twitter @NYTriCaster
    Jan 2017
    Aachen, Germany
    8
    Ok. Only way to handle it is to drop newtek?
    Apr 2008
    Racine
    1,673
    What I've gathered is that the current TriCaster software records the QuickTime files using the XDCAM codec, which IS still supported by Premiere. It is the older Newtek SpeedHQ codec compatibility that may be losing Adobe support.
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Jan 2018
    Winter Park
    557
    Is that what is generated by the ISO recordings of a TC1? I tried the exporter once, was significantly longer than drag and drop to hard drive. I am on 2017 CC and it hasn't complained but I'm sure I'll have to upgrade sooner or later
    Jan 2017
    Aachen, Germany
    8
    Jeff
    Where did you find this XDcam-codec? I've updated my Tricaster 410 AE to newest Version and still don't find any way to change the codec.
    Apr 2008
    Racine
    1,673
    No, there is no option to set the codec. Just when you RECORD in TriCaster, it creates a .mov file and that QuickTime file should use the XDCAM codec inside it. Versus older TriCasters that recorded .mov using Newtek SpeedHQ codec.
    Jeff Pulera
    I just did some testing using TC1/VMC1 along with TriCasters using Advanced Edition 2 and Standard Edition software. Other than some odd-ball 720p formats (like 30, 25 and 24fps) and 4K recording formats all other common (1080p, 1080i, 720p and SD) video formats recorded out of these systems worked without issue on Adobe Premiere v12.1, Avid Media Composer v2018 and DaVinci Resolve v14.3. In all cases, if you are working with a video format that isn't compatible, you can use the TriCaster export tool to create a ProRes 422 file that will work in these applications.
    Right now I've tested these applications on Windows 10 64-bit, don't know yet if it is different on OSX. I'll try to get around to test those as well at some point.
    Jan 2017
    Aachen, Germany
    8
    We are using the TriCaster 410 AE - so there is no chance to switch to newer formats (or XDCam) for us at the moment.
    I saw that you are still selling 410&460 machines in your catalog. How can you do so with no solution to this problem? Is there any chance for a codec-update on these machines?
    I've tested TriCaster Standard Edition, Advanced Edition 2, TC1/VMC1 and IsoRecorder. This covers pretty much everything that is currently sold by NewTek. Here are the results.
    https://www.newtek.com/blog/tips/new...rding-formats/
    Jan 2014
    Nashua, NH
    30
    I remember looking in the past and could not find how to check our build of isoCorder?
    Dan Young
