Thread: UYVY -> RGB Conversion
    Oct 2017
    NY
    37
    Hello,
    My program receiving NDI video in UYVY pixel format and then use OPENGL shader to draw it on the screen. The problem is that I can't find correct way to convert UYVY to RGB.
    For HD content I use following code:
    yuv.x = texture2D(u_texture, v_texCoord).g-0.0625;
    yuv.yz = texture2D(u_texture_uv, v_texCoord).rb-0.5;
    rgb = mat3( 1.1643, 1.1643, 1.1643,
    0, -0.213, 2.115,
    1.793, -0.534, 0) * yuv;
    rgb = clamp(rgb,0.0, 1.0);
    It works but picture still have little difference in details with RGB picture that directly provided by NDI SDK
    What the correct way to do UYVY -> RGB Conversion?
    Best Regards,
    Dmitry
    Nov 2017
    Delhi
    3
    Oct 2017
    NY
    37
    Hi Arzoo,
    Thanks for you links.
    Also yesterday Andrew have provided me a shader that used by Studio Monitor
    varying vec4 tx_coord;
    uniform sampler2D video_Y, video_CbCr;
    mat3 ycbcr_to_rgb_mat = mat3(1.16414, -0.0011, 1.7923, 1.16390, -0.2131, -0.5342, 1.16660, 2.1131, -0.0001);
    vec3 ycbcr_to_rgb_vec = vec3(-0.9726, 0.3018, -1.1342);
    void main()
    vec3 col_y_cbcr = vec3(texture2D(video_Y, tx_coord.xy).r, texture2D(video_CbCr, tx_coord.xy).rg);
    vec3 col_rgb = vec3( dot( ycbcr_to_rgb_mat[0], col_y_cbcr ), dot( ycbcr_to_rgb_mat[1], col_y_cbcr ), dot( ycbcr_to_rgb_mat[2], col_y_cbcr ) ) + ycbcr_to_rgb_vec;
    gl_FragData[0] = vec4( col_rgb, 1.0 );
