Thread: CPU usage at 30-40% only
    I seem not not work this out, can anyone help plsss?
    PS Segment memory limit 4096, change from 1024 did nothing to CPU usage.
    PPS With automatic threads it does recognise 22 and uses 22, I have try to force it to 64 but the cpu usage stays at low 36%
    CPU E5 v4, HT off.
    Cheers
    Tomek
    GarageFarm.NET
    The Cheapest Render Farm - 10,000 cores and growing!
    Skype: garage.farm
    7,898
    Run 2nd (and perhaps 3rd) instance of Layout on the same machine, Step Frame 2 (or 3), Offset 1 frame 2nd/3rd scene..
    At least you will have full power of machine used..
    good workaround, but not for me
    I am on the LWSn on 100 computers or so, on fully automated system. so not really
    Cheers
    Tomek
    GarageFarm.NET
    Skype: garage.farm
    7,898
    Not once I was running two and more LWSN on the same machine to fully use CPU, in such situations.
    I'll talk to my developer.
    Cheers
    Tomek
    GarageFarm.NET
    Skype: garage.farm
    7,898
    If application allows just one LWSN per IP of computer in LAN,
    you could try cheating by plugging 2nd Ethernet PCI card to computer,
    give it different IP, than base one (I suppose so built-in mobo),
    and plug yet another cable to it.
    Render Controller will find yet another computer in LAN with completely different LWSN with completely different IP..
