Thread: Control surface stopped working.
    Jul 2013
    Kansas
    470
    My control surface worked yesterday. I turned on the TriCaster and today there are no lights on the CS. I then went and uninstalled the usb drivers, shut down and restarted. It now works. Is this common?
    Registered User Paris MkVI's Avatar
    Sep 2014
    Virginia
    111
    As long as we're using computers, yes. It wasn't a TriCaster issue, but I have seen many times (usually after OS updates) where I had to uninstall USB drivers and restart to get the system to re-install and recognize externals.
    It is an occasional Windows thing (at least I believe it is). It happens once in a great while.
    Tricaster 460
    HD-SDI over coax
    JVC 890 x 2
    Panasonic 370 x 1
    Jul 2013
    Kansas
    470
    Okay. Thanks.
    Sep 2013
    Atlanta
    320
    We have run into this before on our 8000 CS too. Most of the time, unplugging the power from the CS and plugging it back in seems to fix it
    Jul 2013
    Kansas
    470
    I tried unplugging and it didn't help. The only thing that worked it uninstalling the usb drivers.
    19,652
    I've seen cases where simply connecting something to a different USB port caused it to be recognized again. I only mention this because it might be faster than working with the driver. There are days when I hate USB ...
    TriCaster 860 PortaStudio
    Mar 2009
    Mililani, Hawaii
    119
    I have recently had all sorts of little problems with my tricaster. Yesterday, my DDR would not playback audio despite it showing levels on the audio mixer. I tried everything physical- wires and whatnot- until my co-worker suggested rebooting. That worked.
