Thread: FReq: (plagiarism) "Select Phong Break" / alt selection mode
    Axes grinder- Dongle #99
    Seattle
    14,740
    Lightbulb FReq: (plagiarism) "Select Phong Break" / alt selection mode
    There's an interesting selection mode 'we' should swipe from C4D: "Select Phong Break". Essentially, it's a "Select up to a sharp edge" deal. Nifty. Some hardcore coding there I bet, especially dealing with "looping" conditions.
    Praise to Buddha! #resist
    8,079
    How such tool should work?
    You select polygon on f.e. cube with 5x5 polys per side, and entire side is selected, because there is 90 degree between sides?
    It can be done. Calculate normal vector of polygon, and if it's within range defined by user, select poly, and run in loop.
    Seattle
    14,740
    Of course it CAN be done: Maxon did it. Here's the options (c4d 'numeric panel'):
