Thread: Audio Seperation
    Dec 2015
    Green Bay, WI
    18
    Audio Seperation
    My current setup is 1080i SDI inputs and I use input 1 of the analog XLR inputs on my 4800. I currently Split Play by play and NAT sounds between the Left and Right Channels.
    Ideally if possible I would like to record play-by-play on Left and Right (Audio 1,2) Then on Audio 3, 4 I would like to record NAT sounds and In-House PA. Is this something that is possible?
    Sep 2018
    Perth, Australia
    7
    Hey Jbins07,
    Did you manage to figure out a solution?
    I have a similar issue.. i have the 440, with SDI inputs and Nat sound from cameras, however i also want to bring in commentary track via XLR inputs. is there a way to input commentary track and Nat sound at the same time into clip list / playlist
    You can only choose one audio type for an input, either embedded SDI or analog.
