Results 1 to 15 of 27
Thread: Wireless video transmission kit question.
    Jul 2013
    Kansas
    470
    Does anyone here use a wireless video transmission kit. I have one but the range is questionable for what I need it for now. I need something that easily gets 500-600 feet line of sight. I have checked and found that the Cinegears Ghost-Eye Wireless HD &SDI Video Transmission Kit 150M V2 is a nice piece with good range. Anyone care to comment? Thanks.
    We use a Teradek Beam and thats never let us down. Rock solid unit
    Jul 2013
    Kansas
    470
    Cost?
    Aug 2009
    Carriere, MS
    482
    From what I seen on the internet you are looking at 3500 - 5000 for a setup.
    Aug 2011
    Richmond, VA
    955
    Have you found any reviews of that Cinegears kit?
    E. Lee Dickinson | President
    www.avprva.com
    Jul 2013
    Kansas
    470
    There are some video reviews on YouTube which are pretty good. The ones on B&H are mostly good with 2 bad. I need something in this price range for sure. Our budget can't afford 5k.
    Oct 2015
    Wasilla, Alaska
    103
    We use a Teradek Bolt 300 for a basketball and football sideline cam. It has been flawless.
    I've heard great things about the Ghost Eye units. I like that you can input hdmi or sdi and the price is definitely appealing.
    Video Producer, So Calif.
    Apr 2010
    Irvine, CA
    200
    We have the Teradek Bolt 1000 and 3000 and have been VERY pleased! Range is incredible even non-line-of-sight. The only issue that they don't disclose is that it will get blocked by some window tints. Doors, walls, etc usually fine. But going through a glass skyscraper wall without window openings?... nope.
    www.TakeOneDigital.com
    Live webcasting from concept to broadcast * OC/LA/San Diego and Nationwide
    TC's: 300, 455, 460, Mini
    Cams: Sony PXW-X200, Pany HE-120 PTZ
    Cxns: HD-SDI over coax and fiber
    NYC
    3,333
    I'm curious if "rigging" a NewTek Spark to the camera then using the EnGenius WiFi outdoor antenna kit would work? The Spark is $799 for SDI model and has built-in WiFi transmitter with dual diversity antennas. Then the long range EnGenious kit runs for around $160.
    The Spark needs 12V which could go to a pro battery tap but I don't know how much current it draws to estimate how long it would last.
    You will need latest version of AE and you only need to buy your long range WiFi once and add Sparks as needed.
    Just thinking outload
    Take care,
    Jose Burgos
    NewTek Certified Trainer
    www.burgosfx.com
    FaceBook
    Twitter @NYTriCaster
    Jul 2013
    Kansas
    470
    The Spark looks like a viable option but for something else I want to do. I want to possibly add another camera to our stream and this would help with a stationary cam we have on our clock. I could use the Spark on that cam. This would free up another HDMI slot so we could hook up another cam for a different angle. I just have to do some more research on how the Spark actually hooks up to the Mini. I'm not sure how it would work for what I want to do??? My cam has an HDMI output which would go into the Spark but how does the Mini actually receive the signal from the Spark? I've seen literature on it but what I've seen has been pretty generic and doesn't explain enough. Maybe, I'm just too ignorant but I don't quite get it. Do I need a router or a switch.
    My internet is not on a wireless router where I am going to be using it. I wish I had a video to actually see how a hook up would be done.
    NYC
    3,333
    Make sure you have Advance Edition version 5 latest, which includes the NDI HX drivers. Then connect the Spark to the same computer network. The need to be on same subnet mask so easiest way is get a WiFi router switch with GigE Ethernet. Connect all TriCaster NDI equipment to same WiFi router switch
    Jose Burgos
    www.burgosfx.com
    FaceBook
    Jul 2013
    Kansas
    470
    I have the latest version of AE. So a router is necessary and not just a switch?
    NYC
    3,333
    A network switch with WiFi is fine
    Jose Burgos
    www.burgosfx.com
    FaceBook
    Jul 2013
    Kansas
    470
    What if it doesn't have wifi???
    NYC
    3,333
    You just use the Ethernet jack
    Jose Burgos
    www.burgosfx.com
    FaceBook
