Results 1 to 2 of 2
Thread: Can Xpressions Graphics used with Tricaster
    Sep 2017
    Atlanta Georgia
    2
    I have the software "Xpressions" can this software be used on the tricaster to make motions graphics for live and recorded productions. Any feed back is appreciated
    Macro Titan JonRaidel's Avatar
    Sep 2009
    Los Angeles, CA
    214
    Xpressions could be used as a legacy CG using SDI Key/Fill to bring graphics into your Tricaster. a few options:
    1. use two SDI inputs to bring K/F into the system gets you 1 channel of graphics.
    2. build NDI Connect Pro boxes using an SDI I/O card to bring in channels of K/F to Connect Pro and then convert them to NDI sources on the network
    3. wait till Ross decides to support NDI natively with Expressions.
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    Panasonic HDX 900 Cameras
    NDI Connect Pro
    Graphic Outfitters ScoreHD
    Graphic Outfitters Scorebridge
    Livetext 3 w/ LT [Scoreboards 2]
