Results 1 to 15 of 17
Thread: Power Over Ethernet
    Feb 2010
    Portsmouth, New Hampshire
    41
    Power Over Ethernet
    Got my NewTek PTZ camera last week. Using it with a Tricaster Mini and a Wirecast system. Really like it so far. Does POE need to be activated in settings? I'm not able to power the camera with just an ethernet connection. Tried a short run as well (12' cable) but no luck.
    Sep 2005
    NewTek
    1,685
    Are you using a POE + device to power the camera?
    Zane Condren
    NewTek Inc.
    new.tk/call
    Feb 2010
    41
    Quote Originally Posted by Zane Condren View Post
    Sounds like I need an adapter or an injector. Not much documentation or explanation with the camera but did some digging online. I thought it drew power from the switch but worked fine when I plugged the camera in so was more curious than anything. Thanks for the reply!
    Feb 2010
    41
    Found an 8 port switch (4 PoE) on Amazon that was pretty reasonable. That will cover me for awhile. https://www.amazon.com/TP-Link-Gigab...rt+Gigabit+PoE
    Sep 2005
    NewTek
    1,685
    The camera requires POE + also known as 802.3at.
    Zane Condren
    NewTek Inc.
    new.tk/call
    Key Accounts Sales Engineer
    Feb 2010
    41
    Thanks!
    Registered User Red Dog Records's Avatar
    May 2008
    Northern California
    293
    Just FYI, with only POE, the camera will send video just fine, but no motors will move and it will get REALLY hot on the bottom.
    Tricaster 460AE3 + LC-11
    Flypack: Router, switch, backup encoders, captioning devices, audio mixer, UPS, etc
    Cameras: Sony Z280, Z150, Spark & Bird Dog converters
    http://reddogrecords.com
    Jan 2018
    Burbank
    2
    I just got this new camera from Newtek and PoE is not working. I'm receiving an error on the HDMI output that says, "It's af POE. Power shortage!!!". I can't control it via the joystick from the web app or the desktop app.
    I'm providing PoE power from my Cisco 2960-S switch. I have tried configuring the port the camera is on to 15W and 30W. Same error message and results for both wattages. Does this camera want an exact wattage to work? Firmware VHR111
    The PTZ1 requires PoE+ (802.3at) which delvers 30 watts of power. With PoE (802.3af) you will get the electronics to work but there isn't enough power to drive the motors.
    I don't anything about this switch, but it sounds like something else needs to be done to get the PoE+ working. Do all ports support PoE+? On some switches that I've seen, sometimes some ports are limited to what they can support.
    Jan 2018
    Burbank
    2
    Yes, all ports can be configured with or without 802.3af or 802.at. there any dip switches on the camera to accept PoE+ or should this work by default? I'll keep working on the switch but want to confirm the camera is ready for this.
    Sep 2018
    MD
    9
    I am having the same issue. We have two NewTek PTZ cameras and we can see everything but have no control over either of them. Our network guys has looked over the switch to make sure everything is correct and he says that it is according to Cisco. I have the same question as the previous post is there dip switches that need to be switched in order to make this work correctly?
    Sep 2005
    NewTek
    1,685
    Please check with your IT folks on the total amount of power available from your Cisco switches. It's possible that the cameras require more power than your switches can provide. I would try plugging in the AC adapters to the cameras if you can control them with the ac adapters plugged in it is most likely an issue with your switch.
    Zane Condren
    NewTek Inc.
    new.tk/call
    Sep 2018
    MD
    9
    Yes we are working with them now. We did try it with the power supply and everything worked as it should. I just wanted to make sure there was not a setting in the camera that had to be set in order to make the controls work over POE+.
    Apr 2008
    Racine
    1,602
    I will just add that we had a customer with 3 PTZ1 cameras connected to their Cisco, and while they had images from all cameras via NDI, none would move. That is what happens when there is not enough PoE power, camera will come on, but not enough power to actually move the positioning motors.
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
