Results 1 to 15 of 15
Thread: can I ask a ZBrush question?
    Plays with fire sadkkf's Avatar
    Outside looking in
    1,214
    Registering for the ZBC forums, the confirmation email was caught up in my spam filters so while I try to sort that out, I'm wondering if someone can answer a quick question for me.
    I'm drawing a curves with an IMM brush and wonder if there's a way I can start the curve then rotate my object to a different angle then continue drawing the curve. I can't find much about this online.
    Thanks!
    So much water, so few sharks.
    "...all men are created equal." -- US Declaration of Independence
    Yes, just drag the mouse just a little bit away from the end of the curve where you have a red line connecting them and just keep drawing.
    Outside looking in
    1,214
    OH, man. Thank you! A very subtle visual cue, but now that I see it, it does work.
    And, can you help with an alpha question?
    I loaded a PNG as an alpha with the standard brush. Using DragRect, the corners are fading out even though it's supposed to be square. RF is set to 0 in the alpha modifier. I can post a screen grab is that helps. It's driving me crazy.
    Thank you!
    North Carolina
    11,399
    Quote Originally Posted by sadkkf View Post
    Thank you!
    Can we see the image? If there is any 100% black in the png you are using as an alpha it will be transparent in zbrush.
    Outside looking in
    1,214
    Here are the grabs:
ID:	137909Click image for larger version.
    The alpha is square with a perfectly black border. I can't post it because it was part of a set I paid for.
    Axes grinder- Dongle #99
    Seattle
    14,737
    My guess is that it has something to do with that FALLOFF parameter. Set that to zero and see what happens.
    Praise to Buddha! #resist
    Outside looking in
    1,214
    Tried that, too. No change.
    no the focal shift set to zero at the top of your screen not in the brush modifiers panel
    Outside looking in
    1,214
    Quote Originally Posted by gerry_g View Post
    Yikes. That did it...but why? Setting it to -1 worked.
    Go to Alpha<Modify<Midvalue. Start with a value of 50 and go up or down from there until the edges disappear.
    Outside looking in
    1,214
    I've tried that, too, and it didn't help. I'm still wondering why Focal Shift does.
    Seattle
    14,737
    When you find out, please post.
    Outside looking in
    1,214
    I found this after searching the web:
    "Size of the falloff of the brush in relation to the brush size."
    From here:
    https://www.quora.com/What-is-focal-shift-in-ZBrush
    Seattle
    14,737
    From here:
    ??? Does that make any sense, that name to that function??
    no expert on ZBrush but when you use an alpha it completely replaces all the brush attributes, meaning they do nothing, all of those attributes in the brush panel are to do with the look and feel of any stroke you are building and are only in play with a regular brush not an alpha. The settings at the top of the screen are for strength and radial falloff of the brush stroke or alpha you are using, if it wasn't set up like this you would be forever diving into the brush pallet to adjust your brush strength, not to mention you would be forever altering a brush look that you took some time to set up, so you want to alter the amount you alpha or brush affects your surface or you want it to have a falloff or no falloff use the the settings at the top of the screen, hitting spacebar brings them up in a mini dialogue panel too I believe.
