Results 1 to 10 of 10
Thread: broken polys?
    Registered User Captain Chaos's Avatar
    Oct 2006
    Philadelphia
    154
    broken polys?
    Having an issue in modeler (see attachment). How do I get rid of this and/or keep in from happening in the future?Click image for larger version.
    8,232
    Looks like you have duplicate of entire object, one slightly offset in some places from other.
    If they're not permanently connected, select polygon and press "Select Connected", to select one version,
    cut it to 2nd layer, or offset it a bit.
    If they're connected together, Merge Points, (tell us whether there are found merged points),
    then Unify Polys (also tell us what it reported),
    then Weld Points in broken regions, selecting 2 points at a time, and running Weld.
    Oct 2006
    Philadelphia
    154
    Thanks for getting back to me.
    Select connected selected everything; when I cut everything was gone
    Merge points did nothing at the default setting or at a distance of 5 mil
    Unify polys said "no polygons eliminated"
    clicking where edges intersect shows only one point selected (nothing to weld)
    8,232
    In that case, compress object to zip and attach it in reply, so we will be able to check it..
    8,232
    I loaded it in LW v11.0.3 32 bit Windows, pressed tab, to disable sub-patches, pressed tab again, to enable them again, and distortions that were visible are gone.
    After saving, and reloading they're gone also.
    Oct 2006
    Philadelphia
    154
    That's not working on my Mac
    Oct 2006
    Philadelphia
    154
    I started having problems when I mirrored it.
    8,232
    Ahh, you're using Catmull-Clark Sub-Patches.
    Press Sub D-Type on the bottom panel and pick up SubD-Type: Subpatch.
    Then tab, and tab again.
    Oct 2006
    Philadelphia
    154
    It worked, thank you
