Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: nuArchitect Bundle released
    May 2017
    Lampertheim, Germany
    129
    Hi together,
    now it's finally done. The nuArchitect Bundle is ready.
    At first a big thank you to Markus from 3dworks for doing some MAC tests in the early time of nuArchitect Bundle. Because of a test via mail is not the fastest option, I have looked for a MAC. And I found a 2nd Hand one at low cost. So I was able to do the final tests for MAC's.
    I decided to release this bundle as Donationware. This means, you can use the software for free, but if you enjoy it, please donate via PayPal to [email protected]. This will enhance the chance for updates and new scripts.
    The bundle is packed in 3 zip files. In the file "nuArBunHelp.zip" you will find a file called "Install.html". Open this file in your browser and follow the instructions to install the bundle.
    I would be happy to get some responce to this bundle.
    nuArBunDat.zip
    nuArBunLS.zip
    nuArBunHelp.zip
    nuArBunHelpImg1.zip
    nuArBunHelpImg2.zip
    nuArBunHelpImg3.zip
    nuArBunHelpImg4.zip
    Because of upload Problems, the Images for the helpsystem are splitted in 4 files. You have to copy the files from the splitted files into the "img" Folder of your "Help" Folder. the files "nuArBunHelpImg1", "nuArBunHelpImg2", "nuArBunHelpImg3" and "nuArBunHelpImg4" should be handled as if they where in "nuArBunHelp".
    I hope this does not lead to complications.
    ack ack Markc's Avatar
    1,360
    It may be useful to include a couple of screenshots and a description of what these do, its not too clear from the zip names
    Personally I don't like downloading files 'blind' without knowing what they actually do (especially if they are zips).
    congratulations for the release, karl!!
    very happy to do the first tests for you and glad you found a mac as well, in the end. ;-)
    these scripts are really useful and rather unique tools especially for those doing archiz with LW, but i guess there are a lot of other applications as well if you want to use them 'creatively'...
    cheers
    markus
    3dworks visual computing
    demo reel on vimeo
    instagram
    OSX 10.12.x, macpro 5.1, nvidia gtx 980 ti, LW2015.x / 2018.x, octane 3.x
    1,360
    Markus, any clue as to what they do?
    May 2017
    129
    Hi Markc,
    nuArchitect Bundle is a script bündle to give you the Tools to create the following things with only some clicks:
    nuArches.ls to create arches and bows gothic and romans as well as normal door arches,
    nuCathCei.ls is to create cathedral like ceilings and hallways,
    nuCirclePlan.ls is to create circle brick-walls,
    nuColumns.ls is to create gothic and roman like columns fluted ones and unfluted ones with fluting in or out,
    nuDoors.ls is to create doors with peepholes and lattice, handle and hinges, with bows like gothic and roman,
    nuFences.ls is to create fences,
    nuFloors.ls is to create floors, ordered and random structured,
    nuGates.ls is to create gates scaled, dual and triple ones,
    nuGothXPass.ls is to create gothic x-passes (I don't know if it will be named so in english), in german we say 3-Pass for example,
    nuGroundPlan.ls is to create brick walls from a given ground plan,
    nuOrnaments.ls is to create ornaments like from a blacksmith to build a fence,
    nuPedestals.ls is to create pedestals out of a form and scale description,
    nuRoofGable.ls ist to create roof gables made of single bricks,
    nuRopePath.ls is to create ropes or chains that follow a curved path,
    nuRopes.ls is to create hanging ropes and chains,
    nuRota.ls is to create rotational structures like Roman or greek vases,
    nuSockets.ls is to create sockets with text on the base (like for a Memorial),
    nuWalls.ls is to create walls made of bricks,
    nuWinsGoth.ls is to create gothic and roman windows,
    nuWinsStd.ls is to create Standard windows (mostly modern ones),
    nuUV2TGA.ls is to save a UV-Map as TGA file.
    If you only want to look at examples, than there are the files nuArBunHelp.zip as well as nuArBunHelpImg1-4.zip, they include tons of example pics as well as a Brief description to each script. As you can see, there are tons of files, so pleas accept that there are not a ton pictures here as well. I hope this description is enough to you.
    Regards
    KANUSO
    lot's of them are great to create building details - mostly in a historic scene context. but there are universal tools as well among them which could be used for modern buildings. best is to download them and then the help system will guide you through them ;-)
    demo reel on vimeo
    instagram
    1,360
    Holy cow......just read Kanuso's list.
    These look fantastic
    May 2017
    129
    Hi all Users of the old nuArchitect.ls
    Markus from 3dworks informed me over an issue that can happen, especially on MAC. If you used the old version, than you should go in any of the geometry creating scripts, Switch to the preferences tab and look at the path. If the last letter of the path says "\" on PC or "/" on MAC, than remove the last letter and klick "Store". If you don't do so, the helpsystem on MAC will not work correct. On PC this is no problem, it seems like PC is in this Thing more tollerant.
    Thank you, well done!
    Luci e onde del belpaese - www.lwita.com
    temporary micro preview >
    Member toeknee's Avatar
    Oct 2005
    Houston,Texas
    243
    Thanks, Kanuso, this is awesome.
    The LW Beast From the East
    May 2007
    Belfort, France
    1,845
    Thanks, this seems to be awesome ! I am doing mainly medieval stuff, I'll look into it in detail.
    May 2014
    Aix en Provence
    11
    Installed and tested on Mac, this is VERY nice !! Thank you and PayPal time well deserved !!
    Registered User TeotiGraphix's Avatar
    Apr 2007
    Meredith, NH
    Very nice work, curious how much time you have into the project as a whole?
    Surfing on sine waves.
    http://ww.teotigraphix.com
    May 2017
    129
    Hi TeotiGraphix,
    I do not know the exact amount of time. But I estimate about 230 to 250 hours, the time for developing nuArchitect.ls first version not included.
