Results 1 to 10 of 10
Thread: Restoring M/E Key States To Your Prefered Session Defaults
    Registered User epavideo's Avatar
    Jul 2016
    Washington DC
    78
    I use the COMP Presets bin to "record" M/E Key(s) On/Off States. Since keys are
    toggle-able you don't always know if they're on or off if when you start your session
    or if you've progressed through your shows other macros.
    Setting key states in a macro doesn't record their toggle state and I find the
    "Value" and "Key" fields in the macro editor confusing and unintuitive.
    So to ensure my preferred default session's key "On/Off" settings are set, I record
    each M/E's key's "on/off" status in each key's COMP bin 16.
    Then I create a macro and name it "PrepSession", then do a Snapshot macro recording
    that selects each M/E's COMP bin 16--with the preferred preset key states(the last bin--out
    of the way of any other in-show macros you may set) and Wa-La!! all the keys I am using for a
    session/show are reset to their pre-show status.
    And of course you can also record the states of other things like audio mixer bin presets
    and Hardware Output configurations within this same macro to ensure a preferred session/show state.
    Now if only we had some way of knowing where were are within a session show macros.
    19,397
    Just in case you haven't stumbled on it yet, you can often use the T-Bar commands to force an explicit on or off state.
    Jul 2016
    Washington DC
    78
    That seems unnecessarily pedantic. What about the T-Bar makes it more "sticky" than performing virtually the same task with a key take/auto button?
    Using the shortcut of 'main_dsk1_value' with a value of zero (off) or one (on) will all you to set the status of a keyer. Use 'main' for DSKs on the main switcher or 'v1' thru 'v8' for an M/E. The 'value' command is what a t-bar would perform, and isn't a toggle like the take/auto button.
    For example, 'v2_dsk3_value' with a value of 0 (zero) will turn off the third keyer in M/E2.
    Also, using a web app, it is possible to get the status of the keyers (or most other switcher settings) and have JavaScript perform the logic of what needs to happen next based on that information.
    Jul 2016
    Washington DC
    78
    That sounds more complicated than it probably actually is LOL! Is this something that is covered in NewTek on-site training?
    For now, until I can grasp that info, using comps to reset the state of multiple M/Es seems to be working. My grasp of Macros
    is growing though.
    I've also noticed that I have to avoid embedding Audio Mixer presets into my Macros and just let the 'Follow Program Video'
    dictate what gets audio priority. Otherwise my DDR audio refuses to play consistently.
    Actually re; macros and the LaunchPad S...any chance there will be Tricaster update that will address allowing each Tricaster
    session's launchpad color scheme to be custom only to that session?
    Macro Titan JonRaidel's Avatar
    Sep 2009
    Los Angeles, CA
    216
    create emem files to reset your DSK states and sources.
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    Panasonic HDX 900 Cameras
    NDI Connect Pro
    Graphic Outfitters ScoreHD
    Graphic Outfitters Scorebridge
    Livetext 3 w/ LT [Scoreboards 2]
    Sep 2009
    Los Angeles, CA
    216
    @epavideo
    I should have asked what version of tricaster you are running before saying this.
    but I stand behind my answer of building an EMEM of the M/E State that you would like your switcher to be in.
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    NDI Connect Pro
    Sep 2005
    NewTek
    1,714
    In regards to your question about on site training, each day of training covers up to six of the topics found here http://tc40.newtek.com/index.php/new...s-order-ticket and macros are one of the modules. Additionally we offer Macro assistance/guidance thru our professional services team.
    Zane Condren
    Apr 2017
    San Leandro, CA
    14
    Quote Originally Posted by JonRaidel View Post
    @epavideo
    Would you mind explaining how you build an EMEM of an M/E State?
    Sep 2009
    Los Angeles, CA
    216
    pending which version of Tricaster you have, you can configure your M/E to whatever default setting youd like to save it as.
    On the UI - On the left of the M/E there are 9 preset boxes that popup when you hover over the corner of the M/E. you can click this box to save those settings.
    Right Click the box to either Import/Export the preset memory. in this case export and it saves as a .pst or in newer models .emem file.
    take this a step further and you can program a macro to load this EMEM file into whatever M/E you would like
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    NDI Connect Pro
