Results 1 to 2 of 2
Thread: TC Mini
    Aug 2009
    Carriere, MS
    494
    TC Mini
    Just received a new Mini. Will will be using the HDMI from the cameras and will need about 100ft of cable. Should I get cables with built in boosters or without. Not sure the max I can go with the HDMI cables.
    You definitely will want cables with boosters/equalizers, as normal HDMI cables aren't designed to work anywhere close to 100ft. NewTek does sell a set of four 100ft cables.
    https://store.newtek.com/index.php/a...cable-kit.html
    Make sure you connect the cables the correct way, there is direction that the signal needs to travel thru the cable so they work.
