Results 1 to 15 of 25
Thread: Spark questions
    Mar 2016
    NJ
    33
    Spark questions
    I am very happy to see this new device.
    I have a couple of questions about the HDMI" version
    • What is the wireless protocol. Is it 802.11ac?
    • What is typical wireless throughput?
    • Could this be connected directly into an ethernet port on a computer (to act as a direct wired capture device)?
    • What capacity SD cards does it accept?
    • Does anyone have a screenshot of the web interface, so we can see configuration options?
    • Is a user manual available yet?
    Oct 2008
    Colorado Springs, CO
    37
    Can this device be powered via a PTap connection? If the goal is to be wireless it doesn't make much sense to have to plug into a standard outlet.
    Quote Originally Posted by AlanZ View Post
    What he said! Also interested to find answers to the above.
    A.
    19,348
    Quote Originally Posted by ASD20 View Post
    I honestly don't know, but that's an interesting notion. I'll inquire,
    19,348
    Yes - dual band, 2.4 and 5.8gHz, a/b/g/n.
    There are three bandwidth options (Low, Medium, High) to allow you to work on more congested networks. High is up to 1080p60 ... Medium is 720p, Low is SD. I don't think there would be any problem with a number of "High" bandwidth signals on a single wifi network, if there wasn't much else going on.
    You could capture directly into a computer, sure (the new (NDI) Studio Monitor application included with the HX driver has local capture capabilities), and then there's IsoCorder, etc..
    This isn't really my strong point, but I know the device supports SD, SDHC, SDXC, MMC and eMMC cards.
    I'm attaching a few images below:
    Soon, almost certainly later this week.
    Aug 2015
    london
    228
    This is based on unconfirmed information but is probably correct:
    Q. What is the wireless protocol. Is it 802.11ac?
    A. 802.11 a/b/g/n 2.4G/5.8G dual-band
    Q. What is typical wireless throughput?
    A. up to 15MBit/sec (might be up to 25)
    Q. Could this be connected directly into an ethernet port on a computer (to act as a direct wired capture device)?
    A/ Don't see why not.
    Mar 2016
    NJ
    33
    Steve,
    Thanks for the replies.
    So, in a situation where there is no existing local network, it appears that I could connect a gigabit network switch directly to a laptop computer and plug several Sparks into the switch.
    Does this sound right to you?
    It might be an interesting alternative to using devices like multiple Magewell HDMI to USB3 dongles.
    Would there be any performance/quality improvement or degradation using NDI (for example in vMix) compared to a USB camera input via a Magewell type device?
    Mar 2016
    NJ
    33
    Please let us be more specific about the wireless protocol.
    Is it
    802.11 a/b/g/n 2.4G/5.8G dual-band as stated above or is it (hopefully)
    802.11 a/b/g/n/ac 2.4G/5.8G dual-band
    Aug 2015
    london
    228
    I am guessing its going to be higher latency than Magewell, and the data is going to come in already HX compressed (where it comes in uncompressed via Magewell).
    For a software based processing system which is based on uncompressed frames, there would probably be a larger CPU overhead compared to using a Magwell due to the HX decompression, but its not clear if this would be any more than coming in with regular 100mbit NDI.
    You may not have a DHCP server in the scenario you describe so most likely the Spark boxes would need to be statically configured for IP address.
    Aug 2015
    london
    228
    Is it
    802.11 a/b/g/n 2.4G/5.8G dual-band is correct as far as I can tell.
    Aug 2015
    london
    228
    1 x Micro SD/TF Card
    no info on capacity, but seems like Micro rather than full size cards.
    Mar 2016
    NJ
    33
    So its upper limit is 802.11n ? not 802.11ac?
    That would be unfortunate, mostly in the ability to connect to networks with weak "n" signals but strong "ac" signals.
    Aug 2015
    london
    228
    Presumably you could connect it via ethernet to a wireless interface which does have ac
    Aug 2015
    london
    228
    Power:DC 12V 1A
    Power consumption :4W Max
    19,348
    Power:DC 12V 1A
    I have the same info, will just add that we have not tested this, so while I suspect it would be fine, I can't confirm it.
