Thread: Need help, double fracture
    Feb 2017
    Barcelona
    1
    I'm trying to destroy a stone wall, so when I destroy the wall I want the stones coming from the fracture to fracture again into smaller pieces when they land on the ground. Is there a way to archieve it in lightwave??
    Thanks in advice
    Angry Mac User Otterman's Avatar
    May 2006
    England
    872
    I assume you are talking bullet?
    If you fracture the mesh enough and play around with the glue strength in the graph editor it should help give a secondary fracture. Ie, reduce it at the point of secondary bounce.
    Jan 2005
    Colorado Springs
    1,844
    If I was going to try it, I'd set up each sub-fracturing piece as a separate Parts object in Bullet with the Glue Strength being a Gradient with Y-Distance to Object as the input. Use the ground-plane object as the Object so when the sub-fracturing pieces get "close" to the ground the Glue Strength will suddenly drop to zero.
    mTp
