Thread: Controling Separate Surfaces
    Question Controling Separate Surfaces
    Hello Everyone. It's been a long time.
    I'm learning to code in processing, and while reading some tutorials, I did a script that creates 3D cubes depending on the color/brightness of an image. I did some tests, but now I would like to control the height of each cube separately, could be random, but I want them to grow at different rates. what would you suggest me to do?
    Here's a render test I did.
    https://www.youtube.com/watch?v=0ZSGI8C6hlo
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,689
    Your render test looks interesting.
    Are you able to demonstrate how the script works ( tutorial )?
    8,082
    I guess, your script is Modeler Lscript?
    You should make weight map, and assign index to each of these boxes. Increment index for each box.
    Then in Displacement Node Editor get weight map value and plug to randomizing node, and output use for changing Y position Y (for example).
    I used similar method in video tutorials of TrueArt's TrueTypeText plugin:
    https://www.youtube.com/watch?v=Ow7Um2ks0Ek
    You can see how each letter, each column, each row, each word can be transformed thanks to Weight map.
    Quote Originally Posted by daforum View Post
    Yes, the tutorial is located here: https://www.funprogramming.org/153-R...n-Blender.html
    The script was done in processing, it reads an image brightness per pixel and creates cubes. You just gave me an idea, I'll create a separate script to create a displacement map, so I can get separate heights from each cube. Thanks a lot Sensei!
    May 2006
    Bristol, England
    1,689
    Quote Originally Posted by alanestrada View Post
    Thank you for the tutorial link
    Sure, no problem. Would love to see your tests!
