Thread: TC8000 adv 2 V5 key and fil outputl
    Apr 2017
    Belgium
    20
    Hi ,
    Is someone can give me the way to send key and fill signal as output of the TC8000 adv v5 ?
    I've check on output config for alpha mate but not seen in the menu of the out2
    any help will be appreciate
    thanks
    I don't see the option either, I'll bug it.
    Here is another way to get alpha out.
    Load into one of the M/E's the 'Show Alpha' effect (found in Utilities). Then put this M/E on the second SDI output.
    Macro Titan JonRaidel's Avatar
    Sep 2009
    Los Angeles, CA
    216
    there is a liveset 'Show Alpha' you can select in the M/E, select which source (in this situation Ive used Net1 for a Livetext feed)
    Ive then set the Livetext channel in Net1 Program Row.
    Set output settings Output 1 'Program' and Output 2 ' whatever M/E used'
    I created a macro to set this up and a 2nd macro to reset the outputs back to my normal.
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    Panasonic HDX 900 Cameras
    NDI Connect Pro
    Graphic Outfitters ScoreHD
    Graphic Outfitters Scorebridge
    Livetext 3 w/ LT [Scoreboards 2]
    Apr 2017
    Belgium
    20
    thanks a lot
