Results 1 to 10 of 10
Thread: Streams Stop at 00:00:00;21?
    Jun 2017
    Orange, CA
    3
    Hi!
    So I'm totally new to the Tricaster, and have managed to work through every problem I've encountered either by stalking these forums or through google black magic, so I'm sure this is something I'm just doing wrong, and I can't see it.
    I can use both the Youtube and Facebook presets to connect my account, and they will see my pages, and event information. However, when I hit stream, it runs up to 00:00:00;21, hangs for a minute, then stops.
    Any idea what could be causing this?
    Thanks for your help!
    Best Wishes,
    Sean Slavik
    Feb 2010
    Boston
    398
    This usually means that the stream is not getting through to the proper push point, or that the push point is rejecting it.
    Have you tried RTMP streaming to YT or FB?
    Have you checked your stream resolution and bitrate, to make sure it conforms with what YT and FB expect?
    Jun 2017
    Orange, CA
    3
    Quote Originally Posted by imryh View Post
    This was what I was thinking, but I don't seem to have any sort of feedback to confirm. I've not located any real logs or information to tell me where I'm getting turned away (by the push point, internally at our router, etc.)
    RTMP runs the stream counter, but the response from Facebook is "Offline" and the response from Youtube is "We aren't receiving any data".
    Yup! First thing I did was make sure that the broadcast setup was per Facebook's and Youtube's specs. For instance, my Facebook project is 720p30, and with RTMP was broadcasting at 1280x720 @ 2048k.
    I definitely think that something is blocking the stream, but I've been completely unable to identify what it is. Is there any way to see any feedback from the Tricaster, for instance? Other than the little dropdown left of "Export" that pops up occasionally?
    Thank you!
    Best Wishes,
    Sean Slavik
    Technical Account Manager - Channel Support
    Sep 2005
    NewTek
    1,707
    Check your PM mailbox.
    Zane Condren
    NewTek Inc.
    new.tk/call
    Jun 2017
    Orange, CA
    3
    Zane nailed it! Thank you! I hadn't wanted to screw with updating drivers because of the embedded windows but that fixed it
    Best Wishes,
    Sean Slavik
    Registered User epavideo's Avatar
    Jul 2016
    Washington DC
    78
    We experienced that in my shop. Our stream would stop at 00:00:00:17. Turns out, our I.T. department needed our MAC Address to allow us to push a stream out. Something to do with port forwarding or somthing. ??
    Quote Originally Posted by chance6Sean View Post
    Hi!
    Best Wishes,
    Sean Slavik
    Oct 2006
    Fort Worth, Texas
    23
    Zane I am having same problem on new Mini SDI AE running latest version.
    Can you share the driver update info?
    cjohnson @ bbwcg dot com
    Sep 2017
    Wheelersburg, OH
    9
    Quote Originally Posted by Goglplx View Post
    I am having the same problem as well. HD mini AE
    Sep 2005
    NewTek
    1,707
    Download and install this https://downloadcenter.intel.com/dow...Update-Utility then run it to update your drivers.
    Zane Condren
    NewTek Inc.
    new.tk/call
    Sep 2017
    Wheelersburg, OH
    9
    Worked perfect! The kids will be excited to know that they can go live on Facebook now.
