Results 1 to 15 of 15
Thread: Help With Upgrade
    Feb 2017
    Los Angeles
    15
    Help With Upgrade
    I need help with upgrading software for my VS-100. When I launch the Skype TX application (after login) I see there's a message about upgrading the software.
    But when I go through the process and upgrade the message doesn't go away. Further more, recently I've noticed a orange explanation mark in my Channel 1.
    Please advice.
    The first upgrade was for a new version of Skype TX control, which it sounds like you installed. The second one will come as a TalkShow upgrade, I'm not sure when the next update for that is scheduled.
    19,546
    Could you elaborate on what you mean by "When I go through the process and upgrade ..."? And, Are you running the Skype TX control application locally on your VS-100, or on another system?
    Feb 2017
    Los Angeles
    15
    1. Which update would be the correct one to load?
    Everything is local to the VS-100. I'm running the two applications, “NewTek TalkShow” (Version 2-0-170324) and “Skype TX” (Version 2.16.615.3).
    Please advise.
    Thank you.
    Feb 2017
    Los Angeles
    15
    I just updated to Skype TX version 2.17.601.4. When I run the application I receive a "stxskylibservice.exe - System Error" Stating the following "The program can't start because d3dx9_43.dll is missing from your computer. Try reinstalling the program to fix this problem." I've reinstalled this three times and receive the same error message every time. If I use Skype TX version 2.16.615.3, after I login Channel 1 shows up and states the following "Need to upgrade To access this channel, you will need to upgrade to a later version that supports the newer channel version"
    On Skype TX version 2.17.601.4, after accepting the error message. The system is running very sluggish. The incoming video screen is missing all the information it had before. Also in Channel 1, is shows NewTek TalkShow V2.17.513.1, but I'm running TalkShow-VS-100 Version 2-0-170324.
    Error Message after I launch Skype TX application on version 2.17.601.4:
    Channel 1 information missing:
    Skype TX NewTek TalkShow Channel 1 version is different:
    Feb 2017
    Los Angeles
    15
    Hi guys,
    Any update on this?
    Feb 2017
    Los Angeles
    15
    I see with the new Skype TX version (2.17.601.4) Microsoft removed the Incoming Network Statics. This was very helpful, do you know why?
    May 2015
    netherlands
    12
    VideoGuy,
    I have solution for Error message. Please re-install directX and error wiil stop.
    PLease download only from official MS website.
    1,673
    Quote Originally Posted by CTL Creative View Post
    VideoGuy,
    Download link for DirectX - https://www.microsoft.com/en-us/down...ils.aspx?id=35
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Jun 2012
    peru
    376
    Quote Originally Posted by VideoGuy2017 View Post
    Please advice.
    Hi i have a VS-4000 with the same problem , after update skype Tx and newtek software have the problem when I tried to add a channel, says the v2.16.0915.13 need update
    as you can see i make the 2 updates but the version on the channel is still v2.16.0915.13, what is my mistake?
    Gear Used:
    Tricaster: All 3Play:440
    Cam: JVC GY-HM600, GY-HM150U
    Facebook
    Twitter
    Once you log into the TalkShow from the Skype TX Client, you will see a icon on the bottom of the channel (arrow pointing down). Click on this button and then you can update the channel to the new version. Sometimes it does take a minute before this icon appears at the bottom of the channel.
    I have this problem with TC1 now. Here is a screen shot of the control software:
    I am waiting for a long time but no upgrade icon appears.
    I have the latest TC1 software installed.
    Quote Originally Posted by mzafrany View Post
    What version of Skype TX Control are you running, it might be that you need to update that first.
    https://www.microsoft.com/en-us/down....aspx?id=45887
    Dec 2017
    Australia
    I am also having the exact problem with Skype TX on our Tricaster TC1.
    When connecting to the Tricaster channels in Skype TX I get the following error:
    "Need to Upgrade - To access this channel, you will need to upgrade to a later version that supports the newer channel version"
    This is the first time I've tried to connect Skype TX to the TC1 so I have just installed Skype TX for the first time, the Skype TX version is: 2.17.1101.2
    As far as I know I am running the latest TC1 software as well as I ran an update the same day that I tried to connect Skype.
    I'm currently running a restore on the TC1 to see if that fixes. I will follow up if it does.
    In the meantime any assist you could provide would be great!
    Dec 2017
    Australia
    After a complete restore and re-update to the latest Tricaster software the problem seems to be fixed. Not 100% sure what went wrong before, might have been something during the software update?
