Thread: TC1: Monitoring of Master Channel 3/4 not possible
    Sep 2016
    Freising, Germany
    4
    Monitoring of Master Channel 3/4 via headphones by clicking solo seams not possible with TC1 - with other TC Standard Editions this was possible, because there was a additional fader for Master 2 Output. How can I hear just the sound of Master Channel 3/4? In TC Standard Editions it was possible to route audio signals to Master 1 and Master 2. So then in audio mixer one could choose solo for Master 1 or Master 2 to monitor the signal.
    Is it even possible with TC1 to monitor several audio outputs - solo for AUX1, AUX2, ...?
    Thanks and best regards,
    Pascal
    Apr 2008
    Racine
    1,673
    Hi Pascal,
    Change the routing in the Matrix. That's the only way I know. If you have an unused AUX channel, you could set that up to specifically monitor the channels in question from the other mix.
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    19,658
    Interesting point. Jeff's solution is a good one, I think - I just wanted to mention that if this is something you need to do regularly, you could use macros to make the process more convenient.
