Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: FiberFX Swirl doesn't work with animated objects
    Super Member Boris Goreta's Avatar
    Zagreb, Croatia
    1,358
    Swirl is used to make curly hair and it works on a static object but if I try to animate it using LW bones or MDD swirl doesn't work properly any more. I think it is because normals that fibers swirl around are not being updated when the object is being deformed. I have included project files, one with MDD animation and one with bones animation to illustrate the problem. There are also two example images which show how fibers change shape from the start to the end frame. Please help !
ID:	136915   Click image for larger version.
    Attached Files Attached Files
    no idea,
    did you change the subd value?
    is the preview subd amount and the render subd amount the same value?
    also check subd order.
    seems like a bug?
    Zagreb, Croatia
    1,358
    Subdivision is not used so this is what you get when you render also. I reported a similar bug with splay a couple of years ago but it seems they still didn't fix it. I thought someone knows a workaround.
    I am amazed that in 3 years no one ever made an animation with splay or swirl functions and didn't notice this bug.
    San Jose, CA
    6,879
    Quote Originally Posted by Boris Goreta View Post
    More likely, it was encountered, but the users either couldn't isolate those params as probable cause, or did but didn't publicly discuss it.
    John W.
    it might be related to this bug?
    Fiber FX - Weird behavior
    http://forums.newtek.com/showthread....Weird-behavior
    Zagreb, Croatia
    1,358
    Yes that is the same thing I am having problems with.
    Sydney
    8,282
    I usually use a texture in the Bump channel because of the problem with swirl and some of the other settings.
    Zagreb, Croatia
    1,358
    But you can't make curly fur using bump.
    Registered User safarifx's Avatar
    Mar 2005
    Berlin
    712
    click it...there is no bug if you rendered it with octane.
    https://youtu.be/k0KuNYLsEz4
    snip safx
    Aug 2016
    a place
    2,277
    why would that be, i wonder?
    Registered User Norka's Avatar
    Nov 2015
    NE USA
    344
    safarifx, I had never realized you are LightWaveGuru until just now! You rock! And your bear is bada$$! He can sh!t not only in the woods, but anywhere he damn well pleases!...
    For all of you doomsayers around here, look at what Boris and safarifx/LightWaveGuru are making with LW!.. all effing day long, every day, while you ninnies whine about LWNext, and lack of comms from LW3DG... Go make 3D art yo!
    Mar 2005
    Berlin
    712
    Quote Originally Posted by Norka View Post
    oh sh+t ! my camouflage has been revealed!
    snip safx
    Zagreb, Croatia
    1,358
    This bug has not been fixed in version 2018, well let's give them 3 more years, maybe it happens.
    Fiber FX is terrible, I can't believe they have not updated the setup process. Why update your hair shaders and not touch the clunky setup process, anyone getting any decent hair animation results in 2018?
