Results 1 to 2 of 2
Thread: Bypass AutoStart of 3Play 425 Application
    Registered User Editec's Avatar
    Apr 2012
    Australia
    56
    3Play 425, Current build is not starting correctly after Windows is commenced.
    Require access to EventViewer and other Windows diagnostics to assess the cause of the failure, prior to Restoring the hard drive.
    I’m sure the bypass for AutoStart of the software was either the SHIFT or CONTROL key after Windows has loaded. Though this does not appear to be the case. Can any Forum Member confirm the procedure. With thanks in advance.
    Apr 2012
    Australia
    56
    The AutoStart for 3Play can be disabled via Administrative Tools/Task Scheduler/3PlayXD.
