Results 46 to 60 of 63
Thread: RHiggit Face Factory Beta discussion
  1. #46
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,534
    The only thing that comes to mind is that the plugin is specifically looking for the license file in the Lightwave install tree - c:\program files\newtek\lightwave2018.0.6\support\plugins\fol der\rhdata - for the file. I use an OS trick (SymLinks or Junction Points, I forget which) to make it look like my external plugin folder is actually there, and I have had no problems.
    I would also check file permissions on the folders to make sure it can be read.
    My Scripts for Lightwave
  2. #47
    Feb 2019
    Andersson
    Hi. I am having problems with scaling and a few usage questions. LW2019.0.1
    I have a figure that is 1.66m. Head is about 20cm from chin to top of head. I cannot rig the face with out the bones being messed up in some way.
    I found out that the size that fits best is 0.4. But if i scale it before or after BUILD it will eventually mess up bones.
    If i build in size 1.0 and rig after that i seem to be moving the bones out of the inteded design. It will mess up.
    Any thoughts?
    The wireframe image shows the difference between the preset build and my lwo.
    I get some different results all together. I suspect me or LW more than RHFF. What is best practice ? Load an object first and apply the plugin ?
    From where should i use bones ? (Use bones from..) Self or object seems to work from time to time. Other times the FaceControlRig...
Name:	Anmærkning 2019-02-09 004520.jpg
ID:	144058Click image for larger version.
Name:	Anmærkning 2019-02-09 004330.jpg
ID:	144059Click image for larger version.
Name:	Anmærkning 2019-02-09 004242.jpg
  3. #48
    Nov 2003
    jersey
    5,774
    So... this is an issue with the placement of nulls on splines. Basically... to give movement over the curve of the skull, FF uses splines to track the brows along, and those are drive by nulls which use expressions to place them. There seems to be misbehaviour when things get below a certain size, that causes the nulls to bunch down ear to the start of each spline... it's one of the things Ive been trying to find a good solution for, but it's being a tricky bugger.
    For the time being, I would suggest perhaps increasing the size of your mesh in modeler, so as you're rigging a slightly bigger object, then in layout have the mesh, ad facerig, whole hierarchy thing, parented to a master global null which you can then scale down to shrink the character overall (once you've completed the rigging). Its a bit of a fudge, but might serve you for the time being.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
  4. #49
    Feb 2019
    Andersson
    Thanks for your answer. It is not such a big issue to do a work around. I tried several times with different settings. Happy to hear it was not related to my work.
    An idea could be presets ? Adult, Child, manga, chibi...(and probably many more..) These proportions differ a lot from the human skull.
    This object I would call mild manga. Real manga is totally out of human proportions (just mentioning this as there are quite a few japanese Lightwavers)
  5. #50
    Nov 2003
    jersey
    5,774
    Anything in the Clannad++ space would be just about a no go, imo...
    RHN Nodal Tutorials
  6. #51
    Super Member Kevbarnes's Avatar
    Nov 2006
    Gloucestershire UK
    511
    Just wanted to note this here - for other users:-
    I'm getting an invalid Licence Error come up for FaceFactory in Layout 2019.0.3 (64)
    working fine in Layout 2018.0.3 (64).
    Installed same dir, same plug-ins and same Menu branch into 2019.0.3
    and then get Invalid Licence error.
    I have contacted Rebelhill - he going to check it out -
    @Kryslin - I tried adding Licence file to the RHiggit2/RHData dir like you have shown, but this hasn't worked for me
    "one rig to rule them all"
    PC Spec: Intel i7 X980 3.33GHz | 24Gb | ATI FirePro V5800 | W7
    https://vimeo.com/kevbarnes/showreel
    https://littlstar.com/kevbarnes
    https://www.talenthouse.com/kevbarnes
  7. #52
    Ohio
    963
    Quote Originally Posted by Kevbarnes View Post
    I'm getting an invalid Licence Error come up for FaceFactory in Layout 2019.0.3 (64) working fine in Layout 2018.0.3 (64).
    I'm a fresh FF user and seeing the same licensing error in 2019.1. I'll keep tinkering in 2018.
  8. #53
    pass:sword OFF's Avatar
    Russia
    1,032
    The same things. FF does not want to be licensed for 2019, but normally licensed for 2018.
  9. #54
    Mission Man DaveG's Avatar
    LA California
    49
    Hi- I emailed you as well. Is there a way of changing the resolution (amount of bones) for the lips AFTER you have created the face rig?
  10. #55
    Nov 2006
    Gloucestershire UK
    511
    Quote Originally Posted by DaveG View Post
    You can deactivate any bones that you don't want to use and hide them - but this will change deformation at the mesh.
    Alternatively you can just hide and lock them if you don't want to see them - they will act as 'Hold' bones (subject to their weightmap)
    I haven't used this for some time now as I cant get it work in 2019 ??
  11. #56
    LA California
    49
    I’m looking to alter the existing rig to have more bones in the lips after the fact. I do not wish to merely disable bones.
    I’m running 2018 and it runs fine.
  12. #57
    Nov 2006
    Gloucestershire UK
    511
    You should be able to either clone existing bone into the chain then move them to your new location then rest them or create new bones, make them into joints.
    Sorry if it's not a comprehensive answer
  13. #58
    Feb 2009
    Prescott, IA
    1,534
    Unfortunately, you can't use the face rig builder to change the number of bones in the rig parts. You have to clear the old one out, and rebuild the face rig. There are things you can do to save time on the positioning with the animation toolbox (or any other tool that can save a pose), but yeah, it's a lot of work.
  14. #59
    Virginia
    2,983
    Does this even work in 2019? Is it still being supported?
  15. #60
    2019 is basically 2018 in many ways, so yes, should work fine.
