Page 5 of 12 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 166
Thread: Kryslin's lScripts
  1. #61
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,529
    A bit of fine tuning on my auto-combing script for Lightwave's FiberFX. I solved the issue of being able to overwrite an existing style map. It's a bit faster than the last version of the bias map generator. Instead of using the pesky and crash prone bias map method, this uses what FiberFX calls a "style", which is stored in the model file. As to why I used this character? She's the most complex model I have on my laptop. I've got some shadowing problems on the muzzle, I probably need to tweak a setting or two under FFX.
    The upside to this is that it cuts 4+ minutes off the previous render times, previous renders took upwards of 7 minutes. This took 2m and change.
    (My laptop is a 1st Gen i7 @ 1.6Ghz (boost to 2.8Ghz), so that time is pretty good.)
    My Scripts for Lightwave
  2. #62
    Los Angeles
    7,173
    Cool! Nice work, Kryslin.
    Will you be updating the released tools anytime soon? No hurry, just curious.
  3. #63
    Feb 2009
    Prescott, IA
    1,529
    I think this is release worthy now (provided I remember to remove the debug statement ), but I'd like to update the bias show tool to show the style ( or styles ) embedded in the model file... maybe. Actually, I should be able to do it, because I think the dimensions data will contain the number of dimensions for each entry...
  4. #64
    Feb 2009
    Prescott, IA
    1,529
    Oliver : Style -> Geometry in the OD tools download of 18 July 18 does not have the weight map option. Is this coming in a future release? The strands are created with a hair length weight map, however...
    Edit : never mind, the maps are there... Just no option for it anymore on the tools GUI.
  5. #65
    Feb 2009
    Prescott, IA
    1,529
    Tests are going well, though I would like to improve the mesh following a bit.
    Two more meshes to test on, and this will be ready for release. So, Saturday, maybe?
  6. #66
    Los Angeles
    7,173
    Cool! Will watch out for it and give it a try.
    Thanks for all your hard work!
  7. #67
    cool news!  
  8. #68
    pass:sword OFF's Avatar
    Russia
    1,017
    My first attempt with this scripts - it's very helpful tools!
  9. #69
    Awesome!  
  10. #70
    Feb 2009
    Prescott, IA
    1,529
    I may have hit on the trick to follow the mesh topology last light while working on the problem on paper.
    OFF : And that's the old biascomb script, too. May I ask what version of Lightwave you're using?
  11. #71
  12. #72
  13. #73
    Feb 2009
    Prescott, IA
    1,529
    OFF : Thanks for your answer. Was the model imported from a previous version of LW, or created under 2018?
    The reason I'm asking is that I have had some difficulty with the bias combing script with some of my models, but they are all imported from a previous version of Lightwave, be it 11.x, or 2015.x.
    I also suspect incompatibility between even minor revisions of FiberFX as well.
    *edit* And I've got a good, contour tracing algorithm now. Flow of fur, for the most part, follows the mesh. I need to switch between my old, good for 95% for the time vector routine, and "adjacent point farthest from brush surface" algorithm, or at least blend, at that most problematic of areas... the back of the head.
  14. #74
    Feb 2009
    Prescott, IA
    1,529
    Test results of the new algorithm:
ID:	142373 Click image for larger version.
ID:	142374 Click image for larger version.
    I'm particularly proud of how the area around the eyes turned out.
    And the fail:
    The old algorithm handled this much better.
    Back to thinking...
  15. #75
    quite close though...
