Thread: PySide support
    May 2017
    London
    1
    PySide support
    Hi Guys,
    I've built a little system for the studio I work with PySide in Python and it currently supports 3dsMax, Modo, Unreal and a Stand alone version. I wanted to add support for LW as well so I decided to see if I could get PySide working in LW.
    I wrote the below simple script and tried run it. but I'm getting the following error.
Name:	pyside error.png
    I searched online and I couldn't find much. The only thing I read in another post here, was about x86/x64 bits. Both Python and Lightwave are x64.
    Any ideas?
    Here's the code.
    Code:
    import sys
    sys.path.append("C:/Python27/Lib/site-packages")
    from PySide import QtGui
    __author__ = ""
    __date__ = ""
    __copyright__ = ""
    __version__ = ""
    __maintainer__ = ""
    __email__ = ""
    __status__ = ""
    __lwver__ = ""
    m = QtGui.QWidget()
    m.show()
    Thanks,
    Nick
    Jan 2017
    Lenzkirch
    114
    Any luck on this?
    Mar 2006
    Phoenix
    642
    What version of QT do you have installed on the system and what version is PySide trying to use?
    https://wiki.qt.io/Setting_up_PySide
    To check what version of Qt is used to compile PySide, launch a python console and type:
    import PySide.QtCore
    print(PySide.QtCore.__version__)
    The result should be something like 4.7.4.
    Since the Qt version used to compile PySide may differ from the one used to run it, you might also want to check the current running version of Qt:
    print(PySide.QtCore.qVersion())
