Thread: baby steps with my first node, please help
    Devastatin'
    Jun 2004
    London
    140
    I am very noob at this, I'm using visual studio community and all I am trying to do so far is just get the example source "specular_node.c" to build and run, before I attempted to do anything of my own
    so far I have got the "server.lib" and "specular_node.c" to build in win32, but I get these errors if I try x64:
    Code:
    Error (active)	E1696	cannot open source file "lwserver.h"				server	d:\LightWave 2015 SDK\source\servdesc.c	16
    Error (active)	E0020	identifier "ServerUserName" is undefined			server	d:\LightWave 2015 SDK\source\servdesc.c	21
    Error (active)	E0141	unnamed prototyped parameters not allowed when body is present	server	d:\LightWave 2015 SDK\source\servdesc.c	22
    Error (active)	E0130	expected a '{'							server	d:\LightWave 2015 SDK\source\servdesc.c	22
    Error (active)	E0020	identifier "Activate" is undefined				server	d:\LightWave 2015 SDK\source\servdesc.c	26
    Error (active)	E0065	expected a ';'							server	d:\LightWave 2015 SDK\source\servdesc.c	26
    Error (active)	E0029	expected an expression						server	d:\LightWave 2015 SDK\source\servdesc.c	26
    Error (active)	E0065	expected a ';'							server	d:\LightWave 2015 SDK\source\servdesc.c	28
    Error	C1083	Cannot open include file: 'lwserver.h': No such file or directory	server	d:\lightwave 2015 sdk\source\username.c	14
    Error	C1083	Cannot open include file: 'lwserver.h': No such file or directory	server	d:\lightwave 2015 sdk\source\startup.c	13
    Error	C1083	Cannot open include file: 'lwserver.h': No such file or directory	server	d:\lightwave 2015 sdk\source\shutdown.c	13
    Error	C1083	Cannot open include file: 'lwserver.h': No such file or directory	server	d:\lightwave 2015 sdk\source\servdesc.c	16
    I see no mention of 64bit in the sdk, so I have no idea where to go from here
    Devastatin'
    Jun 2004
    London
    140
    ok the include files reset when you switch to x64, I repointed them and the server.lib compiles, but the plugin still does not, these are the errors I'm getting now:
    Code:
    Error	C3861	'__stosb': identifier not found				specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winnt.h		19111
    Error	C3861	'__readgsqword': identifier not found			specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winnt.h		21336
    Error	C3861	'__readgsqword': identifier not found			specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winnt.h		21347
    Error	C3861	'_InterlockedIncrement': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9023
    Error	C3861	'_InterlockedIncrement': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9032
    Error	C2065	'InterlockedIncrement64': undeclared identifier		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9044
    Error	C3861	'_InterlockedDecrement': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9055
    Error	C3861	'_InterlockedDecrement': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9064
    Error	C2065	'InterlockedDecrement64': undeclared identifier		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9076
    Error	C3861	'_InterlockedExchange': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9090
    Error	C3861	'_InterlockedExchange': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9100
    Error	C3861	'InterlockedExchange64': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9112
    Error	C3861	'_InterlockedExchangeAdd': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9124
    Error	C3861	'_InterlockedExchangeAdd': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9134
    Error	C3861	'_InterlockedExchangeAdd': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9144
    Error	C3861	'_InterlockedExchangeAdd': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9154
    Error	C3861	'InterlockedExchangeAdd64': identifier not found	specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9166
    Error	C3861	'InterlockedExchangeAdd64': identifier not found	specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9176
    Error	C3861	'_InterlockedCompareExchange': identifier not found	specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9189
    Error	C3861	'_InterlockedCompareExchange': identifier not found	specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9200
    Error	C3861	'_InterlockedCompareExchange64': identifier not found	specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9213
    Error	C3861	'InterlockedAnd64': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9223
    Error	C3861	'InterlockedOr64': identifier not found			specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9233
    Error	C3861	'InterlockedXor64': identifier not found		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\um\winbase.h	9243
    Warning	C4090	'argument': different '__unaligned' qualifiers		specular_node	C:\Program Files (x86)\Windows Kits\10\Include\10.0.15063.0\shared\stralign.h	120
    7,993
    These are from standard/system libraries..
    If you don't know function google for its name.
    In their descriptions should be written in which link library they reside.
    Devastatin'
    Jun 2004
    London
    140
    are you saying I need different libraries for 32 and 64 bit?
    Devastatin'
    Jun 2004
    London
    140
    I just installed all the extras visual studio comes with and still get nothing, I don't get it, it compiles just fine in 32bit
