Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: Wow!! Advanced edition 5 early access
  1. #31
    If memory serves, that was removed awhile back now. I've forgotten the reason I'm afraid.
    I am back to AE2 4-0-170313 and I could confirm that LT is outputing to Tricaster output: https://vimeo.com/217296486
    Daniel Choi
    Tricaster 460 AE2 - Tricaster 855 - Tricaster 455
  2. #32
    Registered User AMathews16's Avatar
    May 2015
    Falling Waters, WV
    131
    Ive already reported this to the Developers. Here was what I experienced when I upgraded to the 5.0 series. Unfortunately, I have moved back to the 4.0 series until these issues have been resolved.
    Borders/Shadows
    - The frame increases but the source stays the same size. I have not determined what triggers it so it looks to be at random.
    - Here is an example: https://www.youtube.com/watch?v=H3DN2TbJx-I
    Jagged edges around Camera Source
    - Our Input Source settings for our Cameras are currently set to 1080/30PsF (SDI). I am only seeing the jagged lines when I key the Camera source. When I have Livematte unselected I do not see the edges appear on the Raw Camera Source. We haven't changed any settings on our Cameras.
    - Attached and through this link is an example of this issue. You can specifically see it around our Talent on the right around his Jacket.
    https://www.youtube.com/watch?v=0rsIJAphBqo
    Audio Clipping Error Code when Streaming
    - We are receiving an Audio Clipping Error Code which flashes on the top of the UI. We haven't changed any audio settings before updating. Our workaround for now would be to bring the Stream Audio down -12db. Im sure this might be an bug.
    Switching Comps with Macros
    - There is an obvious glitch when I switch between 2 different comps on an ME only when using a Macro that I created on my Keyboard. However, I can not replicate the glitch if I use my mouse to switch between comp snapshots within the UI.
    - Here is an example: https://www.youtube.com/watch?v=JtrnrqiUAjg​
    Austen Mathews
    Video Production Specialist
    Dept. Veterans Affairs
    TC 1
    Tricaster 8000
    Talkshow 4000
    NC1 I/O
    DANTE VSC
  3. #33
    Aug 2009
    Carriere, MS
    458
    I had some of the same problems. Had tech support log into the system and went back to the vs. 4. Got an email a couple of days ago and said there was an update made after my reported problem. Also note the were able to duplicate the problems I was having. I made the update yesterday and everything looked good and working.
  4. #34
    May 2015
    Falling Waters, WV
    131
    Quote Originally Posted by jkerry211 View Post
    What Build number do you currently have?
    Austen Mathews
    TC 1
    Tricaster 8000
    Talkshow 4000
    NC1 I/O
    DANTE VSC
  5. #35
    Jan 2017
    Nashville, TN
    32
    Quote Originally Posted by AMathews16 View Post
    Borders/Shadows
    Yep. I also have the borders issue, the web stream audio issue, and the switching comps macro issue.
    Had to create my own borders, and significantly lower the web stream audio for it to match all the other output audio levels.
    The switching comp macro would consistently crash when trying to assign the macro to a physical key on the control surface. Only way I could work around was to disable everything but "session macros" and assign it to a keyboard shortcut.
    I am also experiencing some serious latency when selecting GFX2 on the control surface. Not sure if related.
  6. #36
    Quote Originally Posted by CBstudio View Post
    I also had the same issue with latency selecting GFX1 and 2.
    Daniel Choi
  7. #37
    May 2015
    Falling Waters, WV
    131
    When the description says "Early Access", is this essentially saying here is a beta version, download at your own risk?
    Austen Mathews
    TC 1
    Tricaster 8000
    Talkshow 4000
    NC1 I/O
    DANTE VSC
  8. #38
    USA
    499
    Yeah, but they also kind of want folks to try it and help shake out the bugs.
  9. #39
    Jul 2013
    Georgia
    20
    Is there any cohesive update on the AE version 5 software anywhere? I've been watching for several months but haven't seen any actual announcement, maybe I missed it.
    The first response in troubleshooting is always to make sure that I have the current software, but version 5 is still listed as Early Access, which I read as Beta. The user manual also has not been updated (May 2016) and the only documentation that I can find for it is the Read Me which only has minor update information. The version 4 software seems to have stalled with the last version in mid-March.
    I'm on an 8000 v.2 AE.
