Results 1 to 12 of 12
Thread: Free Script: Search Layers
    San Antonio, Texas, USA
    13,057
    Post Free Script: Search Layers
    Another script some might find useful.
    Opens a searchable list of the active object's layers, which you can then select to set as foreground / background layers. Also allows adding to the existing layers.
    Script:
    Search_Layers_v1.0.zip
    Video:
    Search_Layers_Video.zip
    Cheers
    Matt
    UI / UX Designer @ NewTek
    Super Member Chris S. (Fez)'s Avatar
    Virginia
    3,029
    Quote Originally Posted by Matt View Post
    Opens a searchable list of the active object's layers, which you can then select to set as foreground / background layers. Also allows adding to the existing layers.Search_Layers_Video.zipSearch_Layers_Video.zip
    Script:
    Video:
    Cheers
    Matt
    This is ridiculously useful. Thank you.
    13,057
    Quote Originally Posted by Chris S. (Fez) View Post
    Why thank you!
    I ended up demoing this and some other scripts (also on the forum) on the LightWiki Google Hangout:
    https://youtu.be/TEs6DEs_PJg
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,689
    Thanks Matt!
    Will this work with all versions of LW (9.6+)?
    13,057
    Quote Originally Posted by daforum View Post
    Thanks Matt!
    No reason why it shouldn't.
    That said, there is an LScript issue when you have 3,000+ layers, it can cause a crash when the script passes that many items to the listbox. I'm tempted to put in a check for that, or bite the bullet and attempt a Python version (which doesn't have the same issue).
    May 2006
    Bristol, England
    1,689
    Thanks for the info Matt.
    I'll probably never hit the 3000+ layers mark (other LW'vers might though ) but it's good to know.
    Registered User joseba's Avatar
    Dec 2003
    Bilbao
    95
    Thank you very much, Mark.
    I am trying to use the script, but i get this annoying message everytime i type a surface name and hit enter.
    line 274, invalid argument 1 type to srtupper()
    fixed, direct link > https://www.youtube.com/watch?v=TEs6DEs_PJg#t=136m00s
    (need to check this plugin out later on > saved. thanks 
    South Yorkshire, England
    2,500
    Quote Originally Posted by joseba View Post
    Ok - I had this error. I found out it's because you have gaps in your layers (i.e. layers with nothing in them and no name). To combat this I ran Kevin Phillips' Layers Plugin (A collection of layer tools - for moving, deleting and cleaning) which can be found here:
    http://kevman3d.blogspot.co.uk/2013/...-time-for.html
    13,057
    Try this one:
    Search_Layers_v1.1.zip
    Registered User Over's Avatar
    Nov 2016
    Virginia DC
    90
    Daaaaaamn... I was waiting for something like this.
    Thanks Matt!
    I'll probably never hit the 3000+ layers mark (other LW'vers might though )...
    I can hit that mark from time to time.
    Dec 2003
    Bilbao
    95
    Thanks Matt.
    I will try it.
