Results 1 to 13 of 13
Thread: Xpanel envelopes
    Mar 2006
    Global
    670
    Xpanel envelopes
    Xpanel envelopes controls can only be used inside a handler, because they need LWXP_VIEW?
    https://www.deepfxworld.com
    creacon
    Nov 2005
    Belgium
    1,299
    What do you mean?
    Do you mean in comparison to an LWXP_FORM?
    creacon
    Quote Originally Posted by darkChief View Post
    Mar 2006
    Global
    670
    I'm having trouble accessing envelopes. Using an interface outside a handler. All the envelope examples are used inside a handler.
    When I use LWXP_FORM (with an envelope control) the panel crashe's lw. If I use LWXP_VIEW with the set and get functions the controls are disabled. The get and set controls never get called.
    creacon
    Nov 2005
    Belgium
    1,299
    I remember having the same problem, I'll look it up.
    creacon
    Nov 2005
    Belgium
    1,299
    I'll have to check tomorrow, what I can tell you already is that I am using an LWXP_VIEW, the Callbacks get called and I am using envelopes.
    creacon
    Mar 2006
    Global
    670
    Is the interface part of a handler?
    creacon
    Nov 2005
    Belgium
    1,299
    Yes, a master plugin.
    Mar 2006
    Global
    670
    Thanks. Can you use them outside a handler?
    creacon
    Nov 2005
    Belgium
    1,299
    I don't understand what you're asking. All plugins are handlers. An Xpanel is the UI (or part of the UI) of these handlers.
    Can you explain where (outside of a plugin) you would want to use a UI?
    creacon
    Mar 2006
    Global
    670
    I don't like putting my ui codes in handlers because I use singletons to centralise my code. So I rarely use userdata.
    My ui code goes into LayoutGeneric (not a handler right?), this has worked well in isolating frontend from backend.
    So let me rephrase, can you them in LayoutGeneric?
    creacon
    Nov 2005
    Belgium
    1,299
    Ah I see, it seems I have only used Handlers in my plugins.
    How are you building your panel, by passing a hint?
    Mar 2006
    Global
    670
    Yes a hint, and describe.
    Mar 2006
    Global
    670
    Okay got this working in a LayoutGeneric. I wasn't setting things up correctly. You can create your own channel group, no dependence on an item.
