Results 16 to 30 of 41
Thread: Rendering multiple cameras in one scene file
  1. #16
    Grafiks iz us dsol's Avatar
    Sep 2003
    London, UK
    1,855
    Quote Originally Posted by Matt View Post
    Might have a look at this.
    That would be amazing!
    Let me know if you need any enticement (beer - or more than beer - money!)
    Dan Sollis : Independent CGI Designer & compositor
    Digital Distortion : Post Production for Film and Television
    http://www.digitaldistortion.net
    http://www.londonlightwave.org.uk/
  2. #17
    Sep 2003
    London, UK
    1,855
    One idea I had is - is there any way to add a simple script/plugin to cameras that literally just holds start frame and end frame values (set manually by the user - though it'd be awesome to have an auto-range-detect function)? Then once you had that script on all the cameras you wanted to render out from, you could run a master script that looks for the presence of the plugin/script attached to cameras, and uses it to generate the correctly in'n'out-point-set LWS files
  3. #18
    San Antonio, Texas, USA
    13,055
    Quote Originally Posted by dsol View Post
    Already had this in mind.
    If you have a scene with multiple cameras in them, there is no place to set start / end frames per camera, so my thought was a Master script that presents a list of all cameras in the scene, there you'd set the start / end frames for each one.
    UI / UX Designer @ NewTek
  4. #19
    7,901
    Are you familiar with Camera Switcher? There are two such plugins already in LW...
    You're just talking about how to tell master plugin which camera should be rendering which frame..
  5. #20
    13,055
    I am, that script switches to user specified cameras at certain keys as it goes along the timeline - start to end.
    What I believe Dan wants is to have multiple cameras with different start / end ranges that could be something like:
    Camera 1 @ Frame 1 - 10
    Camera 2 @ Frame 1 - 30
    Camera 3 @ Frame 1 - 15
    Etc.
    Even maybe:
    Camera 1 @ Frame 20 - 50
    Camera 2 @ Frame 1 - 45
    Camera 3 @ Frame 128 - 256
    Etc.
    Then save with the output frames set to:
    So Camera Switcher won't even do the switching right.
    Unless of course I'm reading his request entirely wrong.
  6. #21
    13,055
    You know one other way your could do this that might be simpler.
    Put the start / end ranges in the camera name:
    Camera_Name-1-30
    Then, rather than create a whole GUI to manage the start / end frames for each camera. Have a scene export script that loops through all the cameras, extracts the start / end frames and sets up a scene for each camera with the start / end set and the output string changed.
  7. #22
    Sep 2003
    London, UK
    1,855
    That would be perfect. Would you be able to save frame ranges if it was a script though? Be a bit of a pain to re-type them all out every time you want to re-export all the LWS's.
    Thanks again for looking into this. If something like this works, it will literally save me - and others - hours of dull (and human-error-prone) work over the course of a project.
  8. #23
    Mar 2004
    Derbyshire, UK
    3,134
    Camera_Name-1-30
    That's pretty much what I do at the moment. Create a master scene file, call each camera Cam_1-40, Cam_10-60 etc and then copy/paste that camera name into the Output filename box, so all the renders end up in the same folder and I sort them afterwards. If the script could also create a sub-folder for each of the cameras, with the camera name, so that each iteration of the scene saves to the appropriately named sub-folder then that would be golden
  9. #24
    Sep 2003
    London, UK
    1,855
    Camera_Name-1-30
    That's a great way to do it. Maybe put a unique escape sequence of characters, like CXIN and CXOUT, before the in and out numbers so it doesn't get mis-parsed.
    And it has the added bonus that Cameras that don't have the unique identifier in their names don't get used. Cool!
  10. #25
    13,055
    Okay, I have this working.
    Let me double check it first.
    I ended up making it look at the cameras first and last keys for the render range, that way you don't have to manage anything in some GUI.
  11. #26
    Sep 2003
    London, UK
    1,855
    Absolute LEGEND!
  12. #27
    13,055
    Give this a shot, if you want to change the scene file name / save location for the renders etc. Change this line:
    Code:
    new_scene_name = scene_filename_split[3] + "-" + camera_names[s] + " (" + camera_first_key[s] + " - " + camera_last_key[s] + ")";
    Let me know if you find any bugs / need something changing.
    Cheers
    Matt
    Export_Cameras_To_Scene.zip
    Export_Cameras_To_Scene_Files_Video.mov
  13. #28
    Sep 2003
    London, UK
    1,855
    I'll test this out first thing tomorrow morning. I'll have a look at the code too, be interesting to learn more about scripting in Lightwave (and I really should learn Python anyway!)
    Thank you so much for doing this. I love this community - and I love Lightwave!
  14. #29
    13,055
    Yeah I need to start doing stuff in Python vs LScript myself!
  15. #30
    Don't forget to add this to the plugin database!
    www.ernestpchan.com
    www.zazzle.com/gopuggo
