Results 1 to 15 of 22
Thread: Any idead how to model this?
    May 2004
    Melbourne
    61
    Hi all
    In the past I did model a grill with a honeycomb shape and some slots, it was though on a curved surface so they way I did it was to design it on a flat plane and the use the Bend tool to curve the whole thing. Now I have a kinda random surface where I need to apply this and I don't know how to make it to follow the shape of the surface.
ID:	136083   Click image for larger version.
    Spinny Spinland's Avatar
    Apr 2005
    Utica NY, USA
    2,014
    Depending on how steep are the angles, could you get away with a quick-and-dirty extrude and drill?
    “There may be people that have more talent than you, but there’s no excuse for anyone to work harder than you do.” ~ Derek Jeter
    iMac Pro
    "iCan" Mac Pro
    MacBook Pro
    Multiple Mac Minis
    May 2004
    Melbourne
    61
    Quote Originally Posted by Spinland View Post
    I didn't clearly understand to be honest. I've uploaded a sample if you want to give it a go. The honeyconb things must follow the shape curvature of the surface in Layer 1. Don't worry about the excess material that is sticking, that is something I can easily cut.
    Attached Files Attached Files
    Mar 2016
    Oxford, UK
    882
    I can't see your LW file on this machine, but your requirement seems to be describing 3D Sticker plugin from 3rd Powers.
    Registered User Norka's Avatar
    Nov 2015
    NE USA
    344
    I was just going to post that! Go buy 3RD Powers 3D Sticker right now! Mine paid for itself in first 20 minutes of use.
    Apr 2005
    Utica NY, USA
    2,014
    I'd add an endorsement for that plugin, myself. My original idea was if the need were simple and a quick cheat would get the job done.
    Always, always get 3rd Powers' stuff if you can, they are Da Bomb.
    iMac Pro
    "iCan" Mac Pro
    MacBook Pro
    Multiple Mac Minis
    May 2004
    Melbourne
    61
    It seems is what I need. Thanks.
    Super Member samurai_x's Avatar
    Jul 2015
    lalaland
    1,231
    I would do this with textures if its not really extreme closeups.
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,547
    I agree with Samurai_x; textures if you don't need a close up shot of it, otherwise 3rd Powers 3D sticker to conform geometry like this to an object.
    My Scripts for Lightwave
    Textures are ideal and can also be used to displace. But they can cause another set of technical issues depending on the model. Not the least of which is a good clean UV Map.
    But also - again depending on the model - consider other tricks. Such as creating a morph target. (The texture could be projected on a planar basis on the base model) And also modeling flat and then using something like Dragnet.
    For me I would not be able to say anything definitive until I had seen the shape you wanted to make in the end.
    There are a number of tricks you could use once that is first defined.
    not an optimized workflow, but i think you are looking for something like this >
    If the surface can be unfolded, you could model the pattern flat on top of the unfolded shape and conform it to the deformed version using metalink.
    Nottingham UK
    2,757
    Model just the first 2 upper left joined hexagons (by rotating the initial hexagons equally and then bridging the gap).
    Then array clone and weld points automatically. If you had LWCad you could do the cloning with much greater precision as it's interactive.
    Axes grinder- Dongle #99
    Seattle
    14,737
    Quote Originally Posted by ASCIISkull View Post
    #aflw
    Yeah, you could pick points off the random surface, make a matrix/grid, then metalink that to a flat-ish sculpted surface with your details and metalink it.
    It all depends on how much distortion results from the metalink process, I'm assuming you need to preserve the openings in your surface.
    Excellent puzzle.
    Praise to Buddha! #resist
    I think the 3rd Powers plugin is the best option since it really conforms to a surface and doesn't flatten the shape. I had quite a bit of luck with the TC lattice plugin. I got very close and probably could've gotten it very close if I had positioned the two sections at 90 degrees to begin with so that the lattice properly conformed to the shape. It's a free plugin.
    https://www.lightwave3d.com/assets/p.../tc%20lattice/
    However that expensive 3rd Powers sticker looks to be the ultimate solution.
