Thread: Audio Gating Issues on 460
    Dec 2011
    Fort Collins,CO
    6
    Hi, I'm having an audio gating issue that seam to be intermittent. So we updated our 460 to AE2 and ever since, we've had interesting audio gating issues. First off, when you open a new session, audio gating come on as a default, this is bad. Then I noticed that after turning off all gating, the system was still gating audio. Nothing I could do. I tried opening other new sessions- no help. In all of the events we've done, the system was fed by house PA systems but when I checked the feed directly, it was fine, no gating.
    Today I set the system up in our lab to troubleshoot this. I plugged a mic in directly and it was fine, no gating. So I thought it had something to do with line VS mic input so I put a mixer in between the input and sent the 460 line level. Still couldn't recreate the issue.
    Any ideas? Maybe something to do with the level we were being sent? But gating was turned off.
    Thanks,
    Car
    Sep 2005
    NewTek
    1,724
    I would make sure you are running the very latest version of Advanced Edition which can be downloaded from new.tk/dl.
    Zane Condren
    Dec 2011
    Fort Collins,CO
    6
    Yes, I'll check that. Has it been a known issue?
    Thanks,
    Car
    Registered User Red Dog Records's Avatar
    May 2008
    Northern California
    307
    We had the same thing happen to us. The gate was turned off and it was still gating. We ended up switching from line level to mic level and pulling gain way down. The signal was still clean and there was no more gating. No idea why it gated when set to line but not when set to MIC.
    Not the optimum solution, but it worked in a pinch.
    Andrew
    Tricaster 460AE3 + LC-11
    Flypack: Router, switch, backup encoders, captioning devices, audio mixer, UPS, etc
    Cameras: Sony Z280, Z150, Spark & Bird Dog converters
    http://reddogrecords.com
