Results 1 to 14 of 14
Thread: script idea - edit selected texture in photoshop / other app
    maybe i missed something, or is there already a script which opens the current image editor selection right in photoshop (or any other defined application)? currently have to edit a lot of textures from commercial imported assets with terrible file naming conventions, so looking up for them in the file selcetion dialog is driving me crazy. this should work platform indipendent (i am on a mac)...
    cheers
    markus
    3dworks visual computing
    demo reel on vimeo
    instagram
    I like the idea of a script for this very much. While we hope for someone to give it a go, this is what I do when trying to modify an image mapped to an object, while in modeler, Select the surface by activating PickSurf, in layout it's the same thing but using VPR, then shift clicking on the geometry, This opens the surface editor with the appropriate surface selected. Then go to the [T] where the image is (color channel for example) then click on the "edit image" button that is below the thumbnail. Once the image editor comes up with your image highlighted click on Replace, if the list is really long on the file editor select the name it shows below and paste it on the search bar, once they have been filtered right click on the image and select open with.. Once it's modified and saved, go back to Lightwave, close the replace file requester and hit reload on the image editor.
    If anyone is doing this in a faster fashion let us know.
    I believe Sensei already has a plugin that does some of this. At the very least it auto updates the texture in LightWave.
    Even if it doesn't, something like this would have to be a C plugin or in python, not lscript.
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    @ernpchan: yes, probably it needs to access OS informations for file path etc - so probably lscript is not the best way to do it. i'm not an expert, just suggesting the idea here :-)
    @danner, yes that's more or less the way i'm doing now, but when using hundreds of similar named images it is becoming a pain... i wonder why LW does not have this natively, most otehr 3d apps have this option as a native solution, you just need to set it up somewhere in preferences. maybe LW 2017 then? NT are you listening?
    still, if someone would give this a try, i would be happy to pay a small shareware fee. gonna check out truearts plugins as well, but i seem to remember it was windows only.
    EDIT: i found out that blochi did something like this a long time ago, but only for windows. not sure if it is still working with current LW.
    http://www.blochi.com/gfx/imgeditor_en.html
    cheers
    markus
    demo reel on vimeo
    instagram
    It's an LSC so it might work on the Mac, it spits out an error every time you switch images but it works on Modeler 2015 64bits =)
    A bit unrelated but I need to vent a little, I configured Unity to open photoshop when I double click on an image, and it's very cool, but what really frustrates me is that Unity lacks the shift-clicking capability of lightwave dealing with materials, I always have a hard time finding the one I want to edit.
    Update: same thing in Layout 2015 64bits, it spits out an error but works fine.
    Quote Originally Posted by Danner View Post
    it's giving an error here, but then it will open PS but not load the image file. maybe it just needs just a small fix, but unfortunately it's a compiled script.
    demo reel on vimeo
    instagram
    did something like that using an AHK script some time back...
    http://forums.newtek.com/showthread....-AHK-EditImage
    crude hack, kinda works.
    hm, thought that had plugin had stopped working.
    neat  :)
    Quote Originally Posted by 3dworks View Post
    Maybe reach out to blochi to see if he can update it or release it as uncompiled so someone can fix it.
    www.ernestpchan.com
    7,891
    I would drag'n'drop entire image folder to Photoshop at once..
    .. and then use Auto Update Images,
    http://autoupdateimages.trueart.eu
    and start painting in Photoshop on loaded images.
    Because Auto Update Images is using Windows OS functions directly to monitor files on disk without user having anything to do to reload them..
    But TrueArt's Modeling Pack has tool, Reload Images.
    It should be in TrueArtLayoutPack.plugin
    It's ignoring whether file was created right now, or earlier. Simply reloading the all images.
    thanks, good tips. in my case i need to edit only certain textures which i identify inside LW, so the opening in PS first will not help here. actually finding/revealing the selected image (in image editor) in OS finder would help more. but imo a direct functionality to send a selected texture to an image editor is something seriously missing in current LW.
    demo reel on vimeo
    instagram
    I already have a script that does the first part. Just don't know if it'll work on OS as I don't use a mac. The second part should be doable...just wasn't working for me last night. May have been user error in my code.
    www.ernestpchan.com
    Super Member vncnt's Avatar
    Sep 2003
    Amsterdam
    1,567
    cheers
    markus
    I know this is an old thread.
    It was difficult to find documentation about selecting an Image by filename in LScript when all AVI files have unique filenames but have the same name in the image list, so I tried something that you might want to use to feed a spawn() function to feed an external image editor process like krita.exe:
    Code:
    result = "";
    newFileName = "S:\\Content\\myFile.avi";
    index = 0;
    img = Image();
    while(img) {
    	++index;
    	// GET FILENAME AT FRAME 0
    	result += string(string(index) +": " + string(img.filename(0)) + " " + string(img.id) + "   " );
    	// TAKE ACTION
    	if(index==... || img.id==... || img.name=="..." || img.filename(0)=="...") {
    		// REPLACE SPECIFIC IMAGE FILE
    		img.replace(newFileName);
    		// loadimage(); clearimage(); replaceimage();
    		// spawn(); systemex(); wait(); terminate();
    		break;
    	img = img.next();
    Quote Originally Posted by vncnt View Post
    Code:
    result = "";
    index = 0;
    img = Image();
    while(img) {
    	++index;
    	// TAKE ACTION
    		break;
    	img = img.next();
    thanks for getting back!
    as i am no coder, i just wish this could be useful for someone building a complete script or plugin. i will try to ask oliver if he wants to include this into OD tools one day... cheers markus
    demo reel on vimeo
    instagram
