Thread: NDI compatibility
    NDI compatibility
    I'm looking at a PC board that has these specs....
    Processor: Intel Cherry Trail Z8300 Quad Core 1.8GHz
    Operation System: embedded Windows 10
    Ram: 2GB DDR3L
    GPU: Intel HD Graphics, 12 EUs @200-500 Mhz, single-channel memory
    Supports 100Mbps Ethernet
    I'm looking to use them for specific NDI tasks, so I would like to know if anyone can verify if the processor and graphic chip set will be fully compatible with NDI ?
    I'm looking to push a single NDI stream from each device. will 100mbps hold up for one single NDI stream ?
    I'd really like to know for certain..
    Maybe Steve Kane Zane or Martin can advise.
    Thnx A.
    4,231
    That chipset will most likely not allow you to do any kind of capture and conversion. You need a chipset with the AVX instruction set built in. The ATOM (cherry trail) series do not have that instruction set. You should be able to use NDI Monitor on it but the 100 mbps Ethernet speed will leave you wanting more speed to minimize dropped frames and stuttering.
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Panasonic UB300 4k cams
    It would help to know what the tasks are that you plan to uses these units for. I would agree that you should really try to get Gigabit Ethernet on them. Fast Ethernet's max performance the starting bandwidth most people need for NDI. As Jef mentions the CPU could be an issue, those chips do support SSSE3 which is required for NDI, but having AVX instructions is highly recommended, you probably should look for a system with at least Intel i3 CPUs.
    Thanks for the reply guys..
    Currently im grabbing a presenters PC screen fed back to my mini via ndi. I was running a SDI clean feed to a SDI HDMI converter to feed a projector. Now Im feeding the projector via ndi through an i5 laptop running NDI monitor full screen connected to the projectors HDMI port. I want to replace the laptop with a single board computer aka a latte panda board or similar, spec'd above. I'm running either 720p/50 or 1080i/50 if it differs. ( Never higher ) at some events we cover we have dual projector screens and tying up 2 i5 laptops just to feed them seems wasteful of those resources. My initial idea was feeding the projectors via raspberry pi SBC's but i don't think ndi runs on arm devices at this time ?
    A.
    The hub I'm using is 1GB capable, the feed from the presenters PC is 1GB but the single feed to each projector will be via 100mb
    4,231
    Quote Originally Posted by AElli View Post
    Currently im grabbing a presenters PC screen fed back to my mini via ndi. I was running a SDI clean feed to a SDI HDMI converter to feed a projector. Now Im feeding the projector via ndi through an i5 laptop running NDI monitor full screen connected to the projectors HDMI port. I want to replace the laptop with a single board computer aka a latte panda board or similar, spec'd above. I'm running either 720p/50 or 1080i/50 if it differs. ( Never higher ) at some events we cover we have dual projector screens and tying up 2 laptops just to feed them seems wasteful of that resource.
    A.
    The hub I'm using is 1GB capable, the feed from the presenters PC is 1GB but the single feed to the projector will be via 100mb
    I would not suggest going with only a 100mb network feed to the projector in this situation. Gigabit or don't do NDI at this time. Especially with underpowered PCs.
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Jeff, agn thanks for the comeback.
    I've noticed at the lower of ur posts - listings of the gear ur using.
    What's the NDI2HDMI ur referencing ? Might be something I can use in
    my situation above?
    A.
    EDIT : just looked at your web site, I've answered my own question 😀
    Nov 2019
    Texas, USA
    1
    Hi....I'm running into hard crash issues on my vmix box that was running for a week straight no problems.
    I updated NDI earlier in the week, used some sources no problems, but when I set up outbount NDI feeds for recording clean feed to edit social media cuts using the sweet new growing file features, vmix seems to hard crash every 10-30 minutes. I'm slowly paring things back but I am on show day and this is terrifying.
    I'd need to test a lot more until I said what was the deal but the only change today was a reboot and people pulling NDI. I've shut them all off and waiting to see.
