Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: VLC and NDI
  1. #16
    Jun 2012
    peru
    371
    Playing with this a bit. If you use the -p option you can pass into VLC Player the NDI options for video/audio output and not have to set them as the default for the player. Not that it would make a difference for your sync issue, but does streamline using it.
    Example:
    Code:
    streamlink -p "C:\Program Files\VideoLAN\VLC\vlc.exe --aout NDI --vout NDI" https://www.twitch.tv/twit best
    Hi
    do you have any tutorial how use this tool?
    I download the streamlink for windows but not have idea how can configure the vlc
    Tricaster is the best thing that i've used since I played with my atari
    Gear Used:
    Tricaster: All 3Play:440
    Cam: JVC GY-HM600, GY-HM150U
    Facebook
    Twitter
  2. #17
    Quote Originally Posted by alonso View Post
    Hi
    I don't have a tutorial, but all you need to do is install NDI Tools on the system with VLC Player and Streamlink.
    The command line listed above does all of the configuration that you need, it will use Streamlink to start VLC Player with the NDI output active.
  3. #18
    Feb 2014
    Brazil
    2
    Example:
    Code:
    Does anyone using NDI conversion like this on linux host ?
  4. #19
    There isn't a NDI plug-in for VLC Player on Linux, so while Streamlink would work, you aren't going to get NDI output from it.
  5. #20
    Jun 2012
    peru
    371
    Hi!
    can I Use streamlink with facebook live? i test it with twitch and work fine but when use facebook live i get error message on the connection
    Gear Used:
    Facebook
    Twitter
  6. #21
    Hi!
    According to Streamlink, Facebook video is only supported when it is Live and up to 360p resolution.
    https://streamlink.github.io/plugin_matrix.html
  7. #22
    Nov 2018
    nairobi
    2
    Hello guys, Need alittle help here. my vlc player doesnt seem to get the NDI plugin no matter what i do. iam on version 3.0.7.1 I've tried other versions still the same thing. anyone experienced the same? way foward with this? my laptop has windows 10
