Page 48 of 50 FirstFirst ... 384647484950 LastLast
Results 706 to 720 of 737
Thread: Deep Rising Fx: Potential fluid simulator
  1. #706
    Quote Originally Posted by darkChief View Post
    The last frame took about 8-9 min (12 sub-steps per frame). Intel i5 four threads.
    hmm no gpu speedup?
    new web page up www.null.hr
  2. #707
    Registered User darkChief's Avatar
    Mar 2006
    Global
    670
    The current GPU implementation should be able to do something similar if the card has enough memory, it didn't have the same memory limits. The only bottleneck is emitters, those didn't translate well to GPU, but working on that.
    The stability scales on the CPU solver now though. If you had the time you could sim 100,000,000 particles comfortably without worrying about the sim blowing up.
    So maybe distributed Sims in the future may happen.
  3. #708
    Registered User Oldcode's Avatar
    Jan 2004
    Boston
    405
    Hey Dark Chief,
    So, if you're using CPU to simulate the particles, the more cores the better? I have an 8 core system, but with Real Flow, they talk about some simulations where it's actually better to have a single core work on it because the process of splitting the simulation up between multiple cores can add a lot of overhead and actually slow the simulation down.
    Have you seen anything like that?
  4. #709
    Mar 2006
    Global
    670
    Quote Originally Posted by Oldcode View Post
    Hey Dark Chief,
    The more cores you throw at Deep Rising the better. It scales nearly linearly. No splitting is necessary, every particle is part of one huge equation technically, one of the benefits of SPH.
    Splitting to my knowledge is normally used if you're using device's in different memory spaces (multiple GPU's, distributed computers).
  5. #710
    San Jose, CA
    6,495
    Might want to consider a basic NUMA topology check as well, most multipackage systems these days have dedicated memory per package, and thus use multiple distinct NUMA memory domains (f.e. my MacPro has two distinct NUMA memory domains, each attached to a single CPU package).
    In the case of multiple NUMA domains present, having multiple copies of working data (per NUMA domain) is significantly more efficient than forcing a process to reach across to another NUMA domain for memory access. Cache will mitigate somewhat, but cache tag churning also makes coherency between NUMA domains more costly/less efficient. If the main data set is too large to replicate entirely, consider replicating an "access window" of the data set per NUMA domain, and moving the windows around as needed.
    John W.
  6. #711
    Mar 2006
    Global
    670
    Thanks for the tip, will look into it.
  7. #712
    San Jose, CA
    6,495
    What's the current compatibility story for DeepRising and LW2018 and/or LW2019? Do all versions "just work" or are specific versions needed for LW2019, etc?
    John W.
  8. #713
    Mar 2006
    Global
    670
    There's one plugin that works for LW2015-LW2019, and one compatibility version for LW 11. Both are included in a single download.
  9. #714
    San Jose, CA
    6,495
    Also, is there currently any support for either generating "wet maps" with DeepRising? Or, alternately, as node usable for surfacing and displacement (perhaps by setting to track fluid interaction with specific target object)?
    John W.
  10. #715
    Mar 2006
    Global
    670
    Not yet, wet maps I will have to implement at some point. I hadn't thought about incorporating it into the node system. Will add that to the feature requests.
  11. #716
    pass:sword OFF's Avatar
    Russia
    1,010
    Hello. The second day I study the plugin.. The function "Edit selected Rigid objects" does not work for me. I need to assign the same parameters to several dozen objects - I have to do it one by one.
    When you try to add a filter DR Drag - LW immediately crashes.
    When will the manual be updated? Will filters be added for the arena solver? Will the Wind filter be added?
  12. #717
    Mar 2006
    Global
    670
    Quote Originally Posted by OFF View Post
    Will look into the "Edit Objects" and drag filter. In the process of migrating to a new system (old system down), so not sure how quickly I can get that done.
    v2.5 is was the last feature update (as was stated before release), only bug fixes will be released. But wind filter has been noted for the next version. Also arena solver will probably get filter support.
  13. #718
  14. #719
    Mar 2006
    Global
    670
    Deep Rising FX 2.5.2 is now available. This is the first in a series of bug releases that will run parallel to v3.0 development (no road map for that yet). As bugs are squashed updates will be posted, so please be patient.
    FX 2.5.2 Fixes
    - Bullet Convex Hull Decomposition was broken during the update. Fixed now. Now multi-iphysics should be back to normal.
    - Random crashes when saving particle sequences to disk. Fixed now.
    System: AMD Ryzen 2700, 16GB, RX 570 x2, Win 10
    https://www.deepfxworld.com
  15. #720
    Registered User safarifx's Avatar
    Mar 2005
    Berlin
    710
    FX 2.5.2 Fixes
    HOLY MOLY @Dark Chief!
    Its time to test that piece of software for my LightWaveGuru-Channel on youtube!
    p.s. mh....120 Frames for the Demo-Version...i think we need a deal @ Dark Chief....hehe...
    greetnx and later
    safari fx alias LightWaveGuru
