Page 1 of 4 123 ... LastLast
Results 1 to 15 of 46
Thread: Solid to animated destruction (DP PART MOVE)
    Hello fellow wavers,
    I have a bit of a problem. I am trying to animated destruction on a decimated column.
    I have a null going up a column triggering the DP partsMove on rotation so I got the first half of the idea done but
    now I want the pieces to spread out in a blast radius type of movement. The move just pushes the entire column move by 1 m so its not an option.
    I also would to be able to control radius falloff.
    I attached a few pictures to describe what I am doing.
    This is the effect going for
    You have to use the Curve node (it's under Gradient in the node editor) and animate e.g. the Alpha channel.
    With this setup you don't need to use nulls because the curve handles the amount of effect.
    The horizontal axis represents the coordinate axis in 3D, in my case the X axis while the vertical the amount of the effect.
    So if you animate this curve in the editor only horizontally to the right, the explosion effect goes through the geometry.
    Example scene here. Play with the curve node keys in the graph editor. The curve editor is not very intuitive because it behaves in a different way than the original graph editor.
    CurveNodeExplosionWithDPkitExample.zip
    Apr 2016
    Global
    35
    Just curious, wouldn't this be easier with dynamics. Or is there an advantage of doing it this way?
    I only ask as a curious observer.
    there are two things
    -'manual' way gives much more control
    -it requires no calculation
    a downside -can- be that it looks less,... dynamic.
    Axes grinder- Dongle #99
    Seattle
    14,732
    Wouldn't the proper workflow be to get this as close to good as possible, then tweek the result in Chronosculpt?
    I mean, CS is free for 2015 owners.
    Praise to Buddha! #resist
    Registered User darkChief's Avatar
    Mar 2006
    Global
    672
    Interesting...
    Apr 2016
    Global
    35
    okay, thanks for sharing
    Quote Originally Posted by Continuum View Post
    I am working on an anime and I really need artistic control with a hint of real world dynamic-ism.
    I always thought of that as a way to make us complacent since LW NEXT will be more than a year out.
    Bazsa, that sample scene was just what I needed. Not perfect but I can edit it to what I need it for.
    THANK YOU and yes the curve node is hard as hell to control.
    @ jeric_synergy
    Chronosculpt would work, but it couldn't maintain the volume of individual pieces, like for example DP PartMove.
    Seattle
    14,732
    Like I said, make a one-two punch: some dynamics, some Chronosculpt.
    There's a tendency among LW animators to A) try to do everything from one camera and B) get wedded to one methodology, in this case "100% dynamics".
    That's not how this is going to work, if anything it will be a two camera shots sequence and this is nodal work and not dynamics.
    Apr 2016
    Global
    35
    That makes sense, thanks for explaining.
    Nodally, has anyone used a gradient to show part of a morph?
    Never mind --got it!
    Good ol' William Vaugh!
