Thread: Sending frames of NDIlib_FourCC_type_BGRX ?
    Registered User zenvideo.co.uk's Avatar
    Apr 2016
    Salford, UK
    27
    Is it possible to send frames with the FourCC type set to NDIlib_FourCC_type_BGRX? And, if so, what other changes need to be made to the NDIlib_video_frame_t structure?
    I got the impression that maybe by simply setting the FourCC type to BGRX rather than BGRA then the same BGRA (32bit) data buffer could be used for a Send operation but that the Alpha byte would be ignored (and assumed to be 255=opaque). However, when I do so my app crashes.
    Obviously this is a recent addition to the SDK, in which the only BGRX examples seem to relate to the receiving side of things, and the Include file comments (as below) have not been updated to reflect the possibility of three different FourCC values, hence my question.
    // This describes a video frame
    struct NDIlib_video_frame_t
    { // The resolution of this frame
    DWORD xres, yres;
    // What FourCC this is with. This can be two values
    NDIlib_FourCC_type_e FourCC;
    Some further clarification of the use of NDIlib_FourCC_type_BGRX would be appreciated.
    Martin Kay
    ZEN Computer Services - Salford, UK
    19,376
    To avoid any misunderstandings, can I just mention that NewTek's NDI developers do not regularly frequent this forum, which is meant as a means for third-party developers to correspond. Those who are members of the development program all have access to the SDK, which includes the contact details that can be used to direct questions and requests to the NewTek NDI developers. OK, interruption over, back to your conversation.
    Apr 2016
    Salford, UK
    27
    Thanks for pointing that out - I've obviously spent too much time dealing with products for which the main avenue for support was the user forum... (I've now sent an email)
    Martin Kay
    NewTek Engineering ACross's Avatar
    San Antonio
    797
    I do not know of any issue with BGRX crashing, but if you send me an example ([email protected]) it will be fixed immediately if this is the case.
    Andrew
    Apr 2016
    Salford, UK
    27
    Quote Originally Posted by ACross View Post
    Andrew
    There's no issue now, it was fixed long ago , but there was an issue when this thread was started back at the end of August last year...
    Martin Kay
    San Antonio
    797
    Quote Originally Posted by zenvideo.co.uk View Post
    No problems, I do not follow these forums as closely as I should maybe. I do however always respond on [email protected] pretty much immediately.
