Thread: Remapping a 460 control panel
    Mar 2016
    Massillon, Ohio
    5
    With one of the TriCaster updates a second channel of graphics was added.
    Can I remap the 460 control panel to get access to it? Or am I stuck with
    having to use a mouse?
    19,488
    What software edition are you running?
    Mar 2016
    Massillon, Ohio
    5
    Thanks Steve!
    This is a standard edition 2-5-160119
    19,488
    The 2-5 User Guide shows the standard mapping for the 460 CS - in my copy, it's on pg. 374. I just tested to make sure it was correct, and it worked as described. GFX2 is accessed using the same button as GFX1, using SHIFT.
    Mar 2016
    Massillon, Ohio
    5
    Steve, Thanks So Much. Looks like I need to download the newest user manual.
    19,488
    The manual for your installed version is always installed on the system. For an SE Tricaster, it would probably be a C:\TriCaster\Documentation.
