Results 1 to 15 of 18
Thread: Circular Honeycomb
    Visualization FreeLance THIBAULT's Avatar
    Oct 2006
    Rodez, France
    510
    Circular Honeycomb
    Hi Guys,
    Again need you, this time to achieve a circular honeycomb like picture attached. No problem to do this planar, but circular....
    Thanks very much in advance
    Franck
    Member ActionBob's Avatar
    Mar 2011
    Aurora, Colorado
    259
    Measure out the dimension with a length of string for length and height. Then make it planar and bend it in lightwave.
    If you can make it planar no problem, then making it into a round shape should be no problem given enough slices along the verticle so that it can "bend."
    -Adrian
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,689
    You can model it with the bend tool or use Layouts Bend deformer and save a transformed object.
    There is a tutorial on the Layout Bend deformer somewhere and how to set it up if you don't know already, but i can't locate it.
    Aha! Here we go: https://m.youtube.com/watch?v=QNkfGIh_RuA
    Hope it helps
    Super Member kolby's Avatar
    Aug 2004
    CZ, EU
    427
    Quote Originally Posted by THIBAULT View Post
    Hi Guys,
    Franck
    I think you can create one repeatable part of honeycomb structure. Use heatshrink tool to bend it to cylinder with desired radius. Then use radial array and merge points. Done.
    System info: CPU: Ryzen 9 3950X RAM: 32GB DDR4/3200MHz MB: Asus Prime X570-P GFX: Asus GTX 750 Ti / 2GB OS: Win10, LW2019x64
    Carbon fibre dongle® 50one's Avatar
    Jan 2011
    Honeycomb hideout
    2,386
    Quote Originally Posted by kolby View Post
    do planar based on measurements, then bend - 360 degree and merge points.
    South Yorkshire, England
    2,500
    This guy has just been doing this on FB - may be of help:
    Axes grinder- Dongle #99
    Seattle
    14,741
    The repeating elements of that are trivial enough to just brute-force it, no cleverness needed.
    1. Do one hex.
    2. Array it on X to get a row.
    3. copy and offset a row vertically to match, close enough to successfully MERGE POINTS.
    4. dup that a couple times to get enough to fill one square, add the straight borders.
    5. Array THAT enough to fill out an "unrolled" cylinder's worth.
    6. BEND using the LWM BEND tool at 360°.
    7. Apply THICKEN if you need a little depth.
    Easy-peasy.
    Praise to Buddha! #resist
    Oct 2006
    Rodez, France
    510
    Many thanks to all !
    Vacant, pretty vacant pinkmouse's Avatar
    South Yorkshire
    1,704
    Does it really need to be geometry?
    Here's a simple cylinder with some IFW2 textures:
Name:	Screen Shot 2016-08-17 at 12.22.49.png
    Al
    "I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while." Charles Fort
    My Website
    My Lightwave Tutorials
    Seattle
    14,741
    Quote Originally Posted by pinkmouse View Post
    Whoa! That's some impressive node-fu.
    Dec 2004
    San Juan Island
    4,686
    Yep. That's the way I'd do it. Here's a perforated metal with beveled edges:
    Way faster than adding all that geo; especially when the tower is 30' tall.
    Seattle
    14,741
    How does nodal do the depth?
    South Yorkshire
    1,704
    That's what the bits plugged into the normal input do, the IFW2 tile textures allow a "bevel" and that's why I split out the same textures to an alpha, so I didn't get strange semi-transparent stuff going on, but nice clean edges.
    edit: you can do the same sort of thing with the default nodes, but it takes a bit more work and complexity.
    Al
    My Website
    Dec 2004
    San Juan Island
    4,686
    Best to simply take time to watch the tutorials:
    http://www.ifw2.com/IFW2_Nodal/IFW2N..._Tutorial.html
    Seattle
    14,741
    Thanks for the link. I hope it's not too difficult to replicate natively.
