Thread: connect expression CG with tricaster mini
    Oct 2015
    Toronto, Canada
    9
    Hi Newtek
    Is there a way to hookup a Expression CG graphic system to a tricaster mini?
    Rogerstv
    You can get NDI Connect Pro which has Fill+Key input support. You would run NDI Connect Pro another computer with a supported dual input SDI capture card. This tool will convert the incoming signal into NDI, which a current model TriCaster (Standard Edition [Rev 2-5], Advanced Edition 1 [Rev 3-2] or Advanced Edition 2 [Rev 4-0]) system would be able to accept.
    May 2004
    Vancouver, WA
    1,533
    If you aren't running Advanced Edition, you could look at iVGA connect from Graphics Outfitters. It lets you take a key/fill pair and bring it in over a NET input. I'm not sure if Rich has or can update this to also work with NDI on the Advanced Edition, but I bet it is a possibility.
    http://graphicsoutfitters.com/index.php?page=products
    http://graphicsoutfitters.com/pdf/ivgaconnect.pdf
    Kris
    Replay: 3Play 820
    Cameras: Sony NX5
    19,397
    Maybe Ross could add 32bit NDI output ... Now wouldn't that be great for everyone. :-)
    Quote Originally Posted by kltv View Post
    Kris
    The AirSend Updater tool would make this product NDI.
    Sep 2009
    Los Angeles, CA
    216
    Ross or any other traditional broadcast company doing something with 32-bit programming is wayyy to progressive for the industry. my head would explode.
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    Panasonic HDX 900 Cameras
    NDI Connect Pro
    Graphic Outfitters ScoreHD
