Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: NDI for 3Play?
    Feb 2016
    Colorado
    35
    NDI for 3Play?
    I was wondering if there is anything in the pipeline for NDI through a 440 or 840? I would love the option of going full NDI on my productions.
    19,392
    3Play 440 and 4800 will have NDI support in a little while, can't say just when yet, but I'm hoping for by NAB if all goes well. This may not be quite what you're hoping for though; we're not adding support for NDI inputs for 3Play - the primary need seems to be NDI output (A and B).
    Sep 2006
    Peoria, IL
    437
    Pardon my lack of research if this has been discussed or documented, but will a 3Play 425 output to a TriCaster 460 with the new Advanced Edition over the network? Or does this not work because of the NDI implementation? I haven't been able to test it yet.
    Brian
    -- Brian Scheffler
    -- ScheffTech Productions, LLC
    -- ScheffTech.com
    -- Peoria, Illinois
    -- (309) 524-5865
    4,214
    nope. you will need to use hard inputs or roll back to AE V1
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Panasonic UB300 4k cams
    Bloomington, IN
    1,617
    I wish this weren't true. If it did support NDI inputs it would eliminate the need for SDI DAs or Routers. Just sayin'
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
    May 2004
    Vancouver, WA
    1,532
    Could be a resource problem? Similar to the dropping of the number of isocorders on the TriCaster side?
    Kris
    Replay: 3Play 820
    Cameras: Sony NX5
    3PLAY update for NDI now live! Available for 425/820 as well!
    Apr 2012
    Portland, OR
    55
    I was at NAB and listened to the presentation by Don about 3play. He said very specifically that the 3play would accept cameras as an NDI source. Did something change?
    TC40 v2
    TC855
    LiveText
    LT Scoreboard
    JVC cameras (700, 650 & 100)
    19,392
    Perhaps there was some misunderstanding. At present, at least, NDI in to 3Play is limited to the DSK layers. They could be cameras, but these cannot serve as primary replay sources.
    4,214
    Really REALLY hope that is going to change soon. Camera inputs are where we really need the same NDI capabilities. Would be great to go into the TriCaster with hard lines even and then NDI out to the 3Play inputs. Pretty Please??
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    May 2009
    WInnipeg
    57
    I have a 410 AE and a 425 3Play, does this mean I will see the NDI camera sources in the 425? Or will I have to use some sort of software to take the NDI out and put it into a HD-SDI connection and then move it into my 3 Play?
    Registered User GThomas's Avatar
    Nov 2014
    Fargo, North Dakota
    173
    Any hope that this feature will change so cameras can be primary replay sources over NDI? We really want to use NDI to transport cameras to our Tricaster, but if we can't use it with a 3Play, I'm reluctant to go that route. I'd hate to have to run fiber everywhere, so could you maybe explain why this limitation exists?
    Gabe Thomas
    19,392
    Quote Originally Posted by GThomas View Post
    Essentially, it's because various products spring from sometimes similar but not identical code branches, and the architecture can be different enough to make wedging some new feature in rather more daunting. Too, the standard resource burden on a 3Play tends to be somewhat more demanding. I don't want to speculate, so speaking of present possibilities, one wanting to use NDI would need to first supply video over NDI, which would allow one to route and use it as pleased on NDI enabled systems, but convert it back at some point upstream of 3Play's primary inputs. I realize that's not as convenient as we would all like.
    Nov 2014
    Fargo, North Dakota
    173
    Thanks for the clarification, Steve. I figured it would be something like that; I realize 3Play is often more resource intensive, so I can't say I'm surprised.
    We don't have a 3Play right now, but I don't want to adopt a technology that (if we got the money for a 3Play later) would limit us. With no control room at the present time, we're trying to decide what path is next. I was hoping NDI would be that path to make a control room possible, but perhaps I need to explore some other options. Not a deal breaker, but could be in the future if we had the money to expand.
    Gabe Thomas
    NYC
    3,333
    I assume the TriCaster and 3Play are not near each other because you mentioned fiber?
    Jose Burgos
    NewTek Certified Trainer
    www.burgosfx.com
    FaceBook
    Twitter @NYTriCaster
