Thread: kinect problem and "withe page"
Hybrid View
    Jan 2016
    italy
    5
    I try to move the post here is perhaps the most suitable place...
    hello to everyone. I decided to try nevronmotion with kinect on lightwave 11.6 and windows 7 pro. after several problems (plugin, runtime ecc ecc) I have managed to get to the point where in virtual studio> manage device> kinect "open" ... and now I have the same problem on the first page of this tread (http://forums.newtek.com/showthread....-MasterHandler) ... the "white page" of kinect, I do not see anything.
    could someone help me? I also set the name "kinect_A" but in the settings window appears again with the original name _Axxxxxxxxx.
    Thanks for you attention.
    Jan 2016
    italy
    5
    hello, nobody has had a similar problem or have any suggestions? I have reinstalled everything but nothing changes, perhaps plugin problem?
    thank you
    Jan 2016
    italy
    5
    still nothing! to be sure Kinect works I tried it with skanect (3D scanning software), works.
    I installed kinect SDK 1.8, kinect Runtime 1.8. if I remove runtime even skanect does not work. ok.
    in lightwave it could be a problem of conflict plugin "kinect for windows.p "and "runtime/sdk" ?
    * I tried to put the folder nevronmotion inside "user> .newtek>plugins" and also load them manually via "edit plugin windows".
    the device is recognized but not the 'picture appears! I see the white window.
    I have changed the name to "kinect_A" but in the "white windows" still looks like the original ....this be the problem?
    Jan 2016
    italy
    5
    I finally solved. I installed everything and I made sure to enable well kinect in the virtual studio window, I do not know why, but it works.
