Results 1 to 1 of 1
Thread: TriCaster SD- Setting Up iVGA
    Applies to: TriCaster Duo, 100, Pro, Studio, Broadcast, XD300, XD450, XD850, and XD850 Extreme
    Problem Description and Steps to Verify/Reproduce
    The goal of this article is to outline the process of connecting a system running iVGA to a Tricaster unit via standard Ethernet cable. In general, if there is trouble with iVGA not connecting through the network or a router, follow the steps outlined below FIRST. This will eliminate the possibility that the problem is in iVGA or the TriCaster system. Once a connection is established and working settings can be reconfigured to use a router. In order to follow all the suggestions and steps below you will need a working knowledge of networks, navigating the network panels in Windows and setting up connections between machines. Some instruction is provided in these areas but full documentation falls outside the scope of a simple troubleshooting article. NOTE: When using a router, make sure port 5901, 5902 TCP and port 5901 UDP are open.
    Steps to Fix/Workaround
    Connecting the TriCaster to a computer running iVGA via Standard Ethernet Cable:
    1. Check that the PC running iVGA is connected to the TriCaster via a standard Ethernet cable.
    2. Make sure the iVGA computer and the TriCaster both have their IP addresses specified. See section below: “Instructions to set the IP addresses manually.”
    3. Make sure the iVGA computer name is less than 15 characters and the Work Group is the same on both the TriCaster and the iVGA PC. See section below: “Instructions to check the Computer Name and WorkGroup”
    Once the two systems are connected via Ethernet and properly set up:
    1. Launch the TriCaster Software first
    2. then on the other computer, Launch iVGA.
    3. SD TriCaster: Click the External tab, then from the drop down menu for External 1, select the iVGA computer from the drop down list.
      Attachment 124688
    XD TriCaster: Click the drop down menu in the Network Preview Window and select the iVGA computer from the drop down list.
    Instructions to check the Computer Name and WorkGroup:
    For Windows XP PC:
    1. From the Desktop, Right Click on My Computer and Select Properties.
      Attachment 124689
    2. Click the tab “Computer Name”
    3. Click the “Change” button towards the bottom to change the Computer name or workgroup.
      Attachment 124690
    For Windows Vista or 7 PC:
    2. Towards the bottom Click on “change settings”
      Attachment 124691
      Attachment 124692
    Instructions to Set IP address Manually:
    1. Click on Start down in the toolbar, then scroll up to Control Panel. NOTE:In the upper right of the control panel, make sure you are viewing by Large or Small Icons.
    2. In the Control Panel, Click Network and Sharing Center.
    3. Approximately ¼ the way down the screen, Click Local Area Connection. This will open the Local Area Connection Status.
      Attachment 124693
    4. Click Properties in the bottom left.
      Attachment 124694
    5. Select “Internet Protocol Version 4” (TCP/IPv4) and then Click Properties
      Attachment 124695
    6. Under the General Tab, select the option “Use the following IP address:”
      Attachment 124696
      Fill in the following information:
      IP address: “192.168.0.10”
      Subnet Mask: “255.255.255.0”
      Default Gateway: “192.168.0.1”
    7. Click OK, then close the rest of the open windows and restart the PC.
    For Windows XP PC:
    1. Ensure the PC running iVGA is connected to the TriCaster via a standard Ethernet cable.
    2. Click the Start icon, then Control Panel.
      a.Make sure you are viewing the Control Panel in Classic View. You can switch by clicking Switch in the upper left hand of the control panel.
    3. Click Network Connections.
      Attachment 124697
    4. Right Click on “Local Area Connection” and Select Properties.
      Attachment 124698
    5. Highlight “Internet Protocol (TCP/IP)” and then Click Properties.
      Attachment 124699
      Attachment 124700
      Subnet Mask: "255.255.255.0”
    For TriCaster:
    ***Depending on the Model TriCaster, exit to Windows or Admin and follow the steps for Windows 7 or Windows XP. Make sure you set the IP address to be 1 digit different than the other computer. Example: iVGA computer IP address is set to 192.168.0.10, make sure the TriCaster IP address is set to 192.168.0.11.***
    Below is a table of TriCaster Models and the Operating Systems on each:
    Windows XP Windows 7
    TriCaster Duo TriCaster 300
    TriCaster 100 TriCaster 450
    TriCaster Studio TriCaster 850
    TriCaster Broadcast TriCaster 850 Extreme
ID:	131684   Click image for larger version.
ID:	131685   Click image for larger version.
ID:	131686   Click image for larger version.
ID:	131687   Click image for larger version.
ID:	131689   Click image for larger version.
ID:	131690   Click image for larger version.
ID:	131691   Click image for larger version.
ID:	131692   Click image for larger version.
ID:	131694   Click image for larger version.
ID:	131695   Click image for larger version.
    NewTek Customer Support
