Results 1 to 15 of 21
Thread: Override surface values in layout.
    Oct 2014
    UK
    573
    Hi All
    Is there a way to control surface values from outside of the objects surface editor, so I can override values in layout?
    I hope that makes sense
    Vacant, pretty vacant pinkmouse's Avatar
    South Yorkshire
    1,703
    What exactly do you want to achieve? You can use nulls or time/frame to drive surfacing nodal networks.
    Al
    "I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while." Charles Fort
    My Website
    My Lightwave Tutorials
    Oct 2014
    UK
    573
    As soon as you said about controlling using a null, I figured it out. Thanks so much I need to control the colour of a channel, so I am going to use three nodes one for each R G B
    Axes grinder- Dongle #99
    Seattle
    14,739
    Quote Originally Posted by gamedesign1 View Post
    Cool. Post a screenshot of the network when you're done for the education of the newbs.
    Praise to Buddha! #resist
    Oct 2014
    UK
    573
    Will do!!
    South Yorkshire
    1,703
    You can just use one null, RGB=XYZ or HPB...
    Al
    My Website
    Oct 2014
    UK
    573
    Good point! Thanks
    Seattle
    14,739
    Quote Originally Posted by pinkmouse View Post
    Nice. Clutter reduction.
    Of course, there's 9 native channels for Objects, so one could tie, say, Diffuse/Spec/Lum to HPB , etc etc. I think ITEM COMMENT might be helpful to remind one what's what, but then the clutter is starting to build back up. One could also add comments in 1) the Surface Editor and 2) the Node Editor comment field 3) by renaming nodes extensively.
    (I wish there were a DOC NODE that was just for Renaming to add explanations in the Node Editor. Although that's a bit hacky, a real node with a text field in it would be more elegant.)
    Oct 2014
    UK
    573
    Idea for custom inputs in object properties
    Something that would be nice in layout is if you could add custom values to the object properties which you can then access in the surface node editor.
    For example:
    In the object properties panel you could add a 'Color Input' with a reference of 'my_colour'. Then in the Surface Editor using nodes you could add a 'Color Input' node and set its reference to 'my_colour'. I know this is similar to using nulls, but this could be cleaner and also you wouldn't have to clutter your scene with unnecessary nulls.
    Here's an illustration to show what I mean. What do you think?
    7,993
    Take a look at Global Materials.
    http://globalmaterials.trueart.eu
    Oct 2014
    UK
    573
    That looks interesting
    Seattle
    14,739
    I think you could actually do that, probably not as well as w/Sensei's plugin, if you used Instancing, even if for just ONE instance.
    South Yorkshire
    1,703
    I asked for that years ago, and was told it wasn't possible with the current code. But things may well have changed since then.
    However, nulls do have an advantage. You could drive the colour change null with another nodal network, so, say, for instance, an object could change colour at a certain time, but only if another object is within a certain distance. Your imagination is really the only limit.
    Al
    My Website
    Oct 2014
    UK
    573
    Yeah totally agree that NULLs do give you a lot freedom. I just would love to have a way of controlling things without having to place NULLs in the scene, but still have the same flexibility.
    South Yorkshire
    1,703
    Indeed. I also asked for "Global Constants", that could be plugged in to any nodal network in a scene, but didn't even get a reply to that one.
    Have you seen my "Bullet Time" tutorial? It shows the way quite simple node networks are actually very powerful. It's a motion based tutorial, but the techniques are equally as applicable for texturing.
    Al
    My Website
