Page 1 of 7 123 ... LastLast
Results 1 to 15 of 101
Thread: Transitioning from Maya to LightWave
    May 2003
    Moscow, Idaho
    207
    Greetings everyone. I am going to use this thread to ask all of my silly questions about doing similar things in LightWave that I can do in Maya. My first question: Is it possible to quickly cut up an object adding edge loops like I do in the video?
    it's a manhole cover ↓ JoePoe's Avatar
    Jun 2006
    LISA
    1,969
    Edit Edges. Under Details Tab.
    Right click and drag left or right to create new loops.
    Edit: left click to move existing edge loops.
    System Specs: A pile of sand, a couple of wires, a real live mouse and a beer.
    You could use the Knife tool or the Bandsaw tool.
    TrueArt has a tool called EasySplit but it's a commercial plugin.
    http://www2.trueart.pl/?URIType=Dire...-Ins/EasySplit
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    May 2003
    Moscow, Idaho
    207
    Yeah, I tried Band Saw Pro but it was time consuming to do what I wanted to do. The TrueArt plugin looks cool, you can slice through geometry easily. It seams like the knife tool but better. Edit Edges is pretty much what I was looking for. I searched the help file for "adding edge loops" but nothing came up that was relevant to what I was wanting to accomplish. Thank you for the help.
    North Carolina
    11,399
    The right and left buttons perform different operations with some lightwave tools.
    Quote Originally Posted by bellmore View Post
    The one thing I like about BandsawPro is that you can have presets to automatically add a specific number of divisions at specific intervals. But it's not manually interactive like the other tools.
    www.ernestpchan.com
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,923
    But it remembers its last state which are invoked the next time it's triggered. Priceless!
    May 2003
    Moscow, Idaho
    207
    I have a question about LightWave's extrude tool. When I use extrude, the faces that I extrude are inside out. I can flip them but it seems like there should be a way to extrude and have the faces facing the correct way. I looked up the extrude tool and there doesn't seem like there is a setting that I can enable/disable the problem that I am having. The help file shows text being extruded and the faces are facing the correct way.
    Jul 2014
    Baku
    501
    si,plest answer to ur second question is to use extender instead of extrude. simply hit 'e' and then move it.
    Aug 2004
    Ohio, USA
    4,923
    Yeah- extrude is best used on a flat 2D piece of geometry. Depending on what your intention is you could also use "b" for bevel. Farhad's 'e' and then "t" for move is a good workflow to because you can keep the move tool invoked and just press "e" and immediately move it. When you first press "e" it's not evident that anything has happened, but in reality a new poly has been created on top of the selection. You don't know it did anything until you move it. Maybe not user friendly in that regard but it works.
    Jun 2006
    LISA
    1,969
    Also.... in this particular case.... Smooth Shift.
    Aug 2004
    Ohio, USA
    4,923
    Yep - that's Modeler. A million ways to do something.
    Jul 2014
    Baku
    501
    Woooooooow, it is great to finally see Mrs.Snosrap admiring our beloved modeler. :P (No offence, just kidding)
    Additionally although not fastest for Edge Loops, have a look at Add Edges tool. (details tab) It will give you some similar options to the Split Faces tool in Maya. I can't remember if they added another split tool like that in 2015. Someone else can chime in.
    And Bandsaw Pro even though old and clunkly does have some features worth learning. And it is useful in some situations.
    Axes grinder- Dongle #99
    Seattle
    14,739
    I know it got mentioned, but I'm surprised there's not more pushing of the new-ish Edit Edges: for me it has pretty much relegated BandsawPro to the closet.
    For interactivity it can't be beat.
    Praise to Buddha! #resist
