Results 1 to 1 of 1
Thread: Brown Color of TriCaster Mini Control Surface Edges
    Sep 2005
    NewTek
    1,725
    Owners of TriCaster Mini Control Surfaces may notice the vertical edges around the keys, T-bar, and screws are brown in color as shown in the included pictures. This brown color is a normal byproduct of the laser-based process used to manufacture these components and appears exclusively on the vertical, non-viewable surfaces during standard operation. However, excess brown color is also deposited on the protective cling film that covers this polycarbonate surface and often the discoloration of this disposable film extends to slightly obscure the horizontal, viewable surface of the device. In the photos provided the additional discoloration evident on the film can be seen quite clearly.
    Control Surface with Removable Film Attached (Click to enlarge)
    Attachment 130090
    Attachment 130091
    Control Surface After Protective Film Removal (Click to enlarge)
    Attachment 130092
    (Click to enlarge)
    Attachment 130093
    STEPS TO FIX/WORK Around
    Removing the plastic film from the control surface will resolve the issue. Brown coloration on the top of the control surface should no longer be visible. Edges inside the T-bar and other vertical, non-viewable edges will still have some brown color. This is considered the standard coloration of the equipment.
    NOTES: Cosmetic / packaging issue only; will not affect the equipment performance
    Key Words:
    Browning, Brown, Burned, Burnt, Rust, Control Surface, Mini
Name:	Film Attached 1.jpg
ID:	130130   Click image for larger version.
Name:	Film Attached 2.jpg
ID:	130131   Click image for larger version.
Name:	Film Removed 1.png
ID:	130132   Click image for larger version.
Name:	Film Removed 2.png
    Zane Condren
